Old 03-06-2013, 03:10 AM   #1
Hellaflush
My Ride: 2001 330Ci
E46 330Ci Engine Rebuild and Installation
I picked up a 2001 330Ci with a seized up engine, I really liked it because the body was very strait and in very good condition. I had meet the guy the day before and test drove it but it was making a weird noise so i meet him the following day at a BMW specialist. While the car was being checked out the engine seized up. The mechanic said the timing chain had locked up. I ended up getting the car alot cheaper and a new project began
[IMG] photo 20130215_180524_zps5c1382c2.jpg[/IMG]
I towed it home and began taking it apart, i dont have very good pictures of the removal, i got carried away and forgot to take pictures.
[IMG] photo 20130216_133514_zps24c3f702.jpg[/IMG]
After removing the spark plugs i noticed oil on some of the plugs. i began to turn over the engien and oil sprayed out of the cylinders and the timing chain ended up being fine.
[IMG] photo 20130220_142245_zps0a533d71.jpg[/IMG]
I went on to pull the head to see what the issue was.
The some of the cylinder walls were scared.
I pulled the rest of the engine and transmission out. i decide to not use that engine because i would have to bore and buy oversize pistons.
I decided to buy an engine on craigslist for very cheap out of a wrecked car. the only problem with this engine was it had very little compression. I took the risk and bought it in hope the bottom end was salvageable.
[IMG] photo 20130223_160213_zps5d636813.jpg[/IMG]
I pulled this engine apart and luckly the bottom end was in great shape. It also had a hole in it from the crash but this was not a problem for my welding friend
I will take better and more pictures of the rebuilding process.
I plan on putting new rings, bearing, and all gaskets.
Hellaflush is offline   Reply With Quote
Old 03-27-2013, 04:35 PM   #2
dmvkelo
My Ride: BMW 330 CI
Send a message via ICQ to dmvkelo
Need your help
Hey I bought a330ci I wanna learn some things. 1st thing 1st how I remove the engine
dmvkelo is offline   Reply With Quote
Old 04-21-2013, 07:50 PM   #3
Hatebreed
My Ride: 06 330i
any updates on your progress??
Hatebreed is offline   Reply With Quote
Old 04-22-2013, 07:07 PM   #4
2003silver330i
My Ride: 03 BMW 330i
Looks great OP
2003silver330i is offline   Reply With Quote
Old 04-23-2013, 05:26 PM   #5
///BM3R
My Ride: 330ci...///M3 soon
please keep this updated i like this!!
///BM3R
///BM3R is offline   Reply With Quote
Old 05-03-2013, 02:11 AM   #6
chubakakid
My Ride: Hopeful ///M owner
Feed us more, we're craving it!
Story time haha <3 good luck OP.
chubakakid is offline   Reply With Quote
Old 05-04-2013, 12:21 PM   #7
Hellaflush
My Ride: 2001 330Ci
So I broke my phone a lost all the pictures of the build sorry to disappoint you guys. I will tell you what I did though; I got the other block welded and began rebuilding it. I got the blocked honed by the machine shop, then replaced the bearings and installed new rings. This part was basically just like any other car. I then installed a new head gasket, and head studs. Once the head was installed I installed the vanos system. This process was not to complicated just took some time to make sure everything was correct. Before I did the swap I plugged in the main wire harness to all the sensors on the engine. When I installed the engine I did it without the transmission. I have heard you can do it with the engine and tranny attached but it seemed too difficult to get angle perfect to drop it in. I then installed a new clutch and finished bolting everything back together. When I turned it over and it fired up first try, I had a misfire from a bad coil pack but other than that it runs great. I have about 2000 miles on it, ive had a few minor problems with it but that's about it. If you have any questions just let me know
Old 01-22-2015, 03:38 AM   #8
azatabbasov
My Ride: 2001 BMW 330i
How much did it cost you to rebuild it?
azatabbasov is offline   Reply With Quote
Old 01-23-2015, 02:47 PM   #9
Tangent_
My Ride: '01 330i, '11 Z435i
Very interesting in that just out of curiosity. I've always heard rebuilding our engines is much more expensive than buying a good used engine that can just be dropped in.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 01-23-2015, 02:55 PM   #10
jared_wiesner
My Ride: 1999 328i (M54b30)
To do a full rebuild it definitely is. If as the OP suggested he just had the block repaired, honed and replaced some bearings it could have worked out to the same or less cost than buying a lower mileage used engine. However this could hardly be called rebuilding the engine.
Doing a proper full rebuild where most wearable parts are replaced with new/upgraded it would cost significantly more than dropping in a good used engine.
jared_wiesner is offline   Reply With Quote
Old 07-25-2015, 10:42 AM   #11
ckingnirvana
My Ride: 2003 325i E46
E46 Engine Removal and Installation
Are there any detailed resources available that show the engine removal and installation process for an E46/M54 on this forum that you can recommend? The Bentley Manual, while very good, is not detailed enough, at least not for me. Thx
ckingnirvana is offline   Reply With Quote
Old 07-26-2015, 09:35 AM   #12
markusmarkus
My Ride: 2001 330Ci
OP, what did the old piston rings look like. Were the oil control rings (bottom rings) carboned up?
Old 08-02-2015, 09:50 AM   #13
redfeathers
My Ride: 2001 bmw 330 ci
Well, either the guy died or the motor blew up.
This could be the most popular thread in a long time, but we'll see.
2001 bmw 330 ci 241k miles white AUTO A5S 325Z steptronic
redfeathers is offline   Reply With Quote
Old 12-14-2015, 09:04 PM   #14
///BM3R
Is he still alive???? lol
///BM3R
Old 12-14-2015, 09:04 PM   #15
///BM3R
ikr lol
///BM3R
Old 12-15-2015, 10:59 PM   #16
redfeathers
Well, he said he got it running but I would like to have seen more details.
Old 12-19-2015, 10:57 PM   #17
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I just did an engine in my M3. I removed the engine with the exhaust manifolds and transmission attached. Here are the rough steps:
Drain coolant & power steering systems
Remove radiator
Remove power steering cooler
Remove front bumper
Remove front end clip
Remove intake to the cylinder head (leave TBs on if M3)
Disconnect power steering pump and reservoir
Unbolt steering rack and steering column
Disconnect engine mounts from top
Put car on jack stands
Remove underbody panels and front reinforcement
Disconnect exhaust, driveshaft and shifter
Support engine with shop crane
Remove transmission brace
Unbolt front subframe and lower
Pull out engine and tranny
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
330, engine build, m54, m54b30, rebuild
