Thread Tools Search this Thread Rating: Thread Rating: 202 votes, 4.73 average. Display Modes
Old 03-06-2013, 05:33 PM   #1
My Ride: Lexus
Post Definitive E46 Tensioner Pulley Guide For 323/328/325/330/M3
This thread will help you decide what pulleys you have and what to buy based on the setup of your particular car.
Begin!
For complete up to date write up of this exact blog as well as other amusing and funny blog postings and other bonus info, see my page here: http://www.e46mango.com/2017/04/mang...guide-diy.html
Your M5X and S54 engines have three belt-driven tensioner pulleys. The role of the tensioner is either to provide belt-spacing/traction and to quell crankshaft vibrations due to irregular accelerations from the crankshaft. This is done to prolong the life of belt-driven accessories and likely to quiet engine operation.
When should you replace your pulleys?
If your pulleys are original: replace them.
If you don't know how old they are: replace them.
If they are noisy or have excess play: replace them.
If they have 60,000 or more miles: replace them.
This is a crude diagram of the front of an M5X engine:
(Other engines such as the S50/S52 and S54 are same/similar. Even some Mercedes/Volvo engines use identical belt routing.)
Pulley 1:
There is only ONE part number that all E46s share (E36 S50 and S52 as well). There are some rare instances where some people have reported their car doesn't have this pulley. Always check before you buy!!
Notice the big nub sticking out of it:
Pulley 2: Main tensioner pulley. Your non-M E46 could have either a hydraulic tensioner or mechanical tensioner.
Look at your engine bay with a flash light and/or feel around the tensioner.
If you have this:
You need:
If you have this mechanical ROUND tensioner with HEX-shaped NUT sticking out of it like this:
You need the following: Dayco 89133 purchased at either Amazonian or your local Autozone. It may be under a different part number or name, but if you ask for an a/c tensioner for your E46, it will be the correct part.
This is how the Mechanical Tensioner Dayco 89133 pulley looks:
Pulley 3: A/C pulley.
If your A/C pulley uses a MECHANICAL tensioner as well, you'll again use the Dayco 89133 pulley:
This is the pulley all the way at the bottom. It's usually mechanical (haven't seen a hydraulic setup yet on the E46.) Just check yours to make sure by feeling with your hands or using a flashlight.
Remember: if the tensioner is round and has a hex-shaped nut sticking out of it, it's mechanical and you NEED the Dayco pulley.
Both types of tensioners use different pulleys.
Install tips:
If mechanical, you can use a 16mm or 5/8" socket turned clockwise to ease tension on the tensioner for purposes of removing the belt. Use an extension on your ratchet for extra leverage. Safely remove belt. Then insert appropriate torx or allen-head socket into actual tensioner bolt and turn counter-clockwise to remove bolt that holds the tensioner in.
If hydraulic, you use the bolt that goes through the tensioner to both relieve tension and remove the pulley.
BONUS:
If you want to change the ACTUAL tensioners themselves:
Hydraulic:
Mechanical:
OEM/Ina:
11287512758 (9/02+)
11281433571-1 (up to 9/02)
Common E46 setups: One alternator deflector pulley aka idler pulley, one hydraulic pulley for the main belt, one mechanical pulley for the a/c. (That's how my setup is on my 2002 330i)
Another setup I've seen is: One alternator deflector pulley aka idler pulley, and TWO mechanical pulleys (aka Dayco 89133 pulley) I've seen this on a 2004 330ci.
Your particular setup may vary!
If this has helped you, click on the star-rating at the top of the thread and rate it!
Old 03-06-2013, 07:14 PM   #2
white46
My Ride: e46 323ci
Good thread as I need to do mine some time. Thanks.
white46 is offline   Reply With Quote
Old 03-06-2013, 07:17 PM   #3
tech4tech
My Ride: 2004 325i
Very good write-up
tech4tech is offline   Reply With Quote
Old 03-06-2013, 07:24 PM   #4
My Ride: Lexus
I added more info at the bottom for actual tensioner replacement (aside from pulleys)
Old 03-06-2013, 07:32 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
What colors do they come in? Can I get them in green?
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-06-2013, 07:57 PM   #6
Hovs13
My Ride: E46 325ci
Thanks Mango, I was in the process of trying to figure out what parts I needed and what each pulley was. Good timing for me. This goes a long way.
Hovs13 is offline   Reply With Quote
Old 03-06-2013, 08:06 PM   #7
choxor
My Ride: JDM
Good job, sir.
Old 03-06-2013, 08:11 PM   #8
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
great write-up
* it also might be a good idea to replace the hydraulic tensioner pully bolt as well. mine started to strip after a while.
Devious1 is offline   Reply With Quote
Old 03-06-2013, 09:01 PM   #9
caleb6
My Ride: 2005 330XI
where was this thread two months ago when I was trying to figure out what i needed for the first time.
Thanks Mango, good info that I'm sure i'll reference again in a few years.
caleb6 is offline   Reply With Quote
Old 03-06-2013, 09:10 PM   #10
///MPR77
My Ride: 02 ///M3 Tri-Ped
Awesome Guide!
Perhaps add: aka "idler pulley" on the alternator deflector pulley as most here refer to it as such.
Also torque values for each item where it applies, would be awesome.
Thanks again for your contributions buddy quality work as usual.
Old 03-06-2013, 10:03 PM   #11
Stinger9
My Ride: '04 330Ci
Does everyone see the irony that when we do DIY's for our own, they seemingly always exceed the instructions put forth in TIS or Bentley, or even the bavauto youtube variety? We do better pictures and more detailed instructions, and add all the possible mistakes that others have made before in order to add real world experience to the mix. Our home brew advice is the best.
Old 03-06-2013, 10:13 PM   #12
David McMahon
My Ride: '99 E38 740iL
I did find the online version of the Bentley and find it hard going, only half the page used (due to pictures) still B/W and some text missing from the extreme right, also the hard copy expensive in the U.K
David McMahon is offline   Reply With Quote
Old 03-07-2013, 09:22 AM   #13
chudzikb
My Ride: 04 330ci
Stupid dealer told me there was no replacement pully for the AC pulley, ended up doing the tensioner to get the pulley. Thank you for the part number, will use in the future. Again, thanks for your comprehensive work providing those of us that are as nutty as you the part numbers to do the job correctly the first time.
chudzikb is offline   Reply With Quote
Old 03-07-2013, 09:58 AM   #14
Stinger9
My Ride: '04 330Ci
In defense of the dealer, BMW does not supply the pulley separately, so if you were the dealer, it would be off limits to go off the ranch to purchase aftermarket parts. The dealer pledges to maintain your vehicle with only genuine BMW parts, and many would accuse them of all sorts of things if they started off the slippery slope of aftermarket parts. Next on the slope would be Chinese parts.
Personally I'd choose to keep the dealer doing just what they do.
Old 03-07-2013, 10:00 AM   #15
Sweetness
My Ride: '01 325i
Add Uro Aluminum Water Pump Pulley
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 03-07-2013, 10:09 AM   #16
Stinger9
My Ride: '04 330Ci
Thumbs up to an Al WP pulley!
But I'd avoid anything from URO. Has shown to be unreliable parts in many instances. Why take the chance where they have demonstrated low quality control standards?
Old 03-07-2013, 10:26 AM   #17
tommy d
My Ride: 2005 330i
So I assume the Dayco 89113 will replace the pulley on this tensioner as well that is on my '05 330i?
Current Vehicles in my stable:
2005 BMW 330i - 126K miles
2005 Mazda Tribute s - 117K miles
1998 Ford Taurus SE - 115K miles
1987 Ford Mustang LX 5.0 - 248K miles
tommy d is offline   Reply With Quote
Old 03-07-2013, 10:45 AM   #18
My Ride: Lexus
Yes, tommy d.
As far as adding water pump pulley, no. this is just the tensioner pulleys. i'll modify the thread title.
Also i want you all to notice the "haters" downrating this thread. I think they're mad
Why on earth would you rate a helpful thread 1-star? If you think you can do better, step up. this thread is to help people. apparently, you aren't. you know who you are. If this has been helpful, please rate it 5 stars. The stars doesn't matter to me, but i'd want to counter any moves by hateful/jealous people.
Moving on
Old 03-07-2013, 10:58 AM   #19
dmax
dmax's Avatar
I'm sorry, they're five-pointed stars, Mang...can't go near them!
Mangofy your E46!
Old 03-07-2013, 11:27 AM   #20
choxor
My Ride: JDM
Yes, tommy d.
Moving on
Yeah, I noticed that, too. Fairly lame.
