Old 04-26-2017, 10:31 PM   #1
rive46ra
My Ride: 03 330Ci
Stock Headlights, HID from factory?
Hey guys!
Picked up an 03 E46 coupe about a month ago. Headlights are a little screwed up. There's some sort of brown resin around the eyes. I don't know if they're stock or aftermarket. But regardless I'm thinking of replacing them. I've been looking around for some new ones. But a ton of postings say "Not compatible with factory HIDS". How would I go about figuring if my headlights are in fact stock/aftermarket HID or not. Your help is always appreciated.
rive46ra is offline   Reply With Quote
Old 04-26-2017, 10:58 PM   #2
Jason325xi
My Ride: 2004 325xi 5speed
The "brown resin" sounds like burnt bowls, search for that here and you should find some good info about how to go about fixing it
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
Old 04-27-2017, 10:24 AM   #3
Hamsocne
My Ride: 2002 330Ci
I agree with what was said above.
Run your VIN through a vin decoder and you will see how your car was delivered from the factory.
Hamsocne is offline   Reply With Quote
Old 04-27-2017, 04:56 PM   #4
turbo8
My Ride: 2002 325i
If you do have the zkw bowls, check out the RETRO-QUIK: BMW E46 / ZKW HEADLIGHT REPAIR KIT you can get it from here:
https://www.theretrofitsource.com/co...kw-repair.html
turbo8 is offline   Reply With Quote
Old 04-27-2017, 05:25 PM   #5
armenh7
My Ride: 2002 325i
imagehost.helluvafast.com/files/2/2/e46HeadlightDriver.jpg These are NOT hid (halogen)
s187.photobucket.com/user/JaredM3/media/DSC_8269.jpg.html These are hid. Notice the little ball, that's a projector. (Hid)
So which one do you have?
armenh7 is offline   Reply With Quote
Old 04-28-2017, 07:57 AM   #6
markusmarkus
My Ride: 2001 330Ci
There's an active recall of ZKW headlamp assemblies.
Old 04-30-2017, 11:24 PM   #7
rive46ra
My Ride: 03 330Ci
I ran the VIN through a decoder. It said I have factory Xenon. I also checked the pictures posted above and looked at the car. I have the HIDS. Now, is there some sort of refresh kit? Where I can make them pretty much new again?
Old 04-30-2017, 11:24 PM   #8
rive46ra
My Ride: 03 330Ci
How would I go about checking if mine is included?
Old 04-30-2017, 11:25 PM   #9
rive46ra
My Ride: 03 330Ci
Sorry for all the noobish questions guys. Your help is greatly appreciated.
Old 05-01-2017, 12:02 AM   #10
armenh7
My Ride: 2002 325i
Type your vin here
bmwusa.com/recall
Old 05-01-2017, 12:05 AM   #11
rive46ra
My Ride: 03 330Ci
Originally Posted by armenh7 View Post
Type your vin here
bmwusa.com/recall
Thanks for the link. Nothing about headlights, but I do have a recall for my driver's airbag.
Old 05-01-2017, 04:29 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Can you post pics of your headlights? You most likely have either Bosch or AL headlights. The brand is on top of the headlight when you open the hood.
Old 05-01-2017, 09:38 AM   #13
rive46ra
My Ride: 03 330Ci
I'll get a picture here in a few ***128512;
Sent from my KIW-L24 using Tapatalk
