Thread Tools Search this Thread Rating: Thread Rating: 85 votes, 4.99 average. Display Modes
Old 09-02-2013, 03:27 AM   #21
Ossetian
My Ride: Bmw 323i 2000
In a document at the end of the post I didnt find a single bulb with 6000K. Why??
Ossetian is offline   Reply With Quote
Old 09-02-2013, 03:38 AM   #22
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
In regards to halogen bulbs or the xenon bulbs?
Old 09-02-2013, 03:45 AM   #23
Ossetian
Cool
Umm...I was asking about Xenon. To me it is the main option as you saying and it looks very good. So I was referring to the table you post in the end of your post which has bulb descriptions. And I did not see any 6000K there. Was just asking cause I need to purchase some 6000K with ballast for myself. Started with your post here
Old 09-02-2013, 03:48 AM   #24
Solidjake
Zero. Leaks.
Solidjake's Avatar
There are two 6000k xenon bulbs listed. The philips Ultinon which is very expensive or better quality aftermarket bulbs which are the Morimoto.
Old 09-02-2013, 03:51 AM   #25
Ossetian
Smile
Thats the only option? damn I thought there would be more. You see, I would like to get good luminosity and I also like bluish glow, not clearly white..
Maybe you have any suggestions?
Old 09-12-2013, 08:36 AM   #26
benman
My Ride: 2004 330 xi
Awesome post... many thanks
benman is offline   Reply With Quote
Old 11-08-2013, 02:11 AM   #27
iWeldonJ
My Ride: 325Ci
Nokya
Bought these 9006 Nokya 2500 yellows from an Amazon seller (autocouture) but the the part that plugs into the socket is a tad longer and so is the bulb. Did I get the wrong size?
iWeldonJ is offline   Reply With Quote
Old 11-08-2013, 02:34 AM   #28
cityjohn
My Ride: 2001 M3
Originally Posted by Solidjake View Post
Made in EURORE is another tipoff.
This is all great info, thanks for the extensive knowledge!
cityjohn is offline   Reply With Quote
Old 03-01-2014, 11:23 PM   #29
cityjohn
My Ride: 2001 M3
Thanks again Jake for this great guide.
Originally Posted by Mango View Post
Good job man. maybe just make this a one stop lighting thread. tail lights, types, brands, sidemarkers, etc etc! sounds like a lot of work already
I'm adding my bulb list as a complement to Jake's (I left the limited headlight info in it just to keep it intact). If anyone has anything to add to it please advise!
If you're replacing bulbs, you should be able to find what you need to buy, If you just need the size to know what LED's to order you could probably also reference the "wrong" bulbs in the last column, for example the notorious 1156.
Old 03-04-2014, 04:44 AM   #30
Solidjake
Zero. Leaks.
Solidjake's Avatar
Very nice John I will add it to the first post when I get back from work
Old 03-04-2014, 09:12 AM   #31
KaktusJaque
My Ride: 2003 325xi
Thanks SJ, I will be using this for sure.
*KJ---Don't Believe Everything That You Think! *
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Clean Your Dirty Wheels
2003 Touring 325 XiT (KJ's Ride)
2004 Coupe 325 Ci (Mrs. KJ's Ride)
KaktusJaque is offline   Reply With Quote
Old 04-28-2014, 04:41 PM   #32
Big Ern
My Ride: 328i
Hello, I'm new here and trying to buy some replacement bulbs for my 328i. It has some aftermarket clear headlamp housings and they're 35w 8000k from what the bulb says. the control is a black box and says "Electronic control for XENON light bulbs". I just want to make sure whatever bulbs I buy will match the plugs that are existing.
Big Ern is offline   Reply With Quote
Old 05-04-2014, 07:21 PM   #33
Solidjake
Zero. Leaks.
Solidjake's Avatar
You do have xenon lights. If you want original yellow output get Philips 85122+ bulbs from theretrofitsource.com For white, either Osram CBI or Morimoto bulbs in 5000k temperature
Old 05-04-2014, 08:32 PM   #34
Big Ern
My Ride: 328i
Thanks for the reply. The issue now is I don't know what brand of headlight housings/projectors I have. One person told me their not d2s and might be H1. How can I tell that and also make sure I buy replacement bulbs with the correct leads coming off them to plug into my harness?
Old 05-05-2014, 10:16 AM   #35
Big Ern
My Ride: 328i
I looked the headlights over and found that the projectors say DEPO on them. Can someone point me in the direction of a reputable retailer for bulbs that fit these projectors?
Old 05-05-2014, 10:19 AM   #36
Solidjake
Zero. Leaks.
Solidjake's Avatar
Hmm, if it's depo then most likely they use H7 bulbs. Can you take a bulb out and post a picture?
Old 05-05-2014, 11:11 AM   #37
Big Ern
My Ride: 328i
******** width="480" height="360" src="http://s1138.photobucket.com/user/ebay225/embed/slideshow/Mobile%20Uploads">*********>
Old 05-05-2014, 11:18 AM   #38
Big Ern
My Ride: 328i
ID:	557101Click image for larger version
ID:	557102Click image for larger version
ID:	557103Click image for larger version
ID:	557104Click image for larger version
ID:	557105Click image for larger version
Old 05-18-2014, 10:57 PM   #39
DonaldE
My Ride: 2002 330i
Quick question:
I just installed my Mtech II bumper and it came with fogs that have 9006 bulb types already in them, but I came from a facelift secan that used H11.
So what can I do to make these fogs compatible?
Is it as simple as just cutting the old leads and putting the correct ones on?
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 07-26-2014, 03:00 PM   #40
RelaxIN
My Ride: BMW 330Ci
Okay my turn.... I just installed a set of Orion V2's 6000 and they look great, however, I still have the factory head/fogs, etc bulbs still installed... I didn't think it was going to bother me all that much, but it does... So now im lookin for a set of replacement bulbs of the same temperature to match the Angel Eyes... I want to see if someone has a similar setup and what they're using... Thanks for any input...
RelaxIN is offline   Reply With Quote
