New Clutch, New Vibration: Personal Experience? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-07-2013, 11:40 AM   #1
lkstaack
My Ride: 04 330iZHP, 05 325iT
My 330i 6-Speed has a low-speed vibration that I feel from the steering wheel and seat. I just installed a new UUC lightweight flywheel / clutch package, UUC transmission mounts (not race), and guibo. The vibration starts when the car first starts to move and disappears at about 30mph. Does anyone have personal experience with a similar issue?
I noticed the vibration as well as a buzzing rattle coming from the transmission tunnel on my first test drive. Thinking the rattle may come from the heat shield, I removed the exhaust and heat shield again. The shield seemed to be good, but I noticed that the transmission support cross member did not fit exactly as when I removed it; the old grease marked where it once was attached, and it was about 5mm off. I loosened all of the transmission support nuts and center bearing cap, and used a pry bar to re-position the cross member to its former location. I was able to get it close, its now about 1mm off. Consequently, the rattle disappeared, but I stall have the vibration.
Here is a video taken shortly after my first test drive and before the rattle went away.
So, anyone have a similar problem? I can live with the vibration, but would rather not.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 03-07-2013, 12:05 PM   #2
lcoleman
My Ride: '79 Massey Ferguson
Polyurethane transmission mounts are almost guaranteed to add at least a little NVH.
Old 03-07-2013, 12:15 PM   #3
HakenTT
My Ride: 323i with S54
crap aftermarket parts
HakenTT is offline   Reply With Quote
Old 03-07-2013, 03:42 PM   #4
Rob Levinson * UUC Motorwerks
UUC Motorwerks, *******
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
Torque spec on the transmission mounts is very important; over-tightening them will cause a vibration. Torque spec is 15ft-lbs which is only a little more than finger-tight.
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
Old 03-07-2013, 05:02 PM   #5
lkstaack
Thanks, Rob. I torqued the bottom nuts to 16lbs, but I guessed on the top nuts because I couldn't get a torque wrench in there. Perhaps they are a little tight.
Lars
Old 03-25-2013, 10:54 AM   #6
NumbaOneNewb
My Ride: 2003 330CI Silver
Does it do that same thing if you're in neutral
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
