Old 03-07-2013, 12:40 PM   #1
taveet330i
My Ride: Jet Black 2002 330i
Car wouldnt start this morning after shutting it off
So I got in my car to go to school this morning and I pulled it out of the garage (started right up on a cold start) and then forgot my wallet so I parked it on the driveway and I shut it off. Not even 2 minutes later I was got back in the car to start it, and it cranked and cranked and I got nothing. I let off the key for 10 seconds and cranked it again. A total of 4 times I had to crank it until it turned over. But when it did, it idled very roughly at about 500-600 rpms. It was sputtering and dying out so I lightly gave it some gas and it went up to 1200 and retarded down to about 900 (which is usual). What caused this slow start? I have replaced all the vacuum lines, all engine seals, gaskets, idle control valve, and the throttle body within the past 4 months. All help is welcome
[bimmerapp]
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 03-07-2013, 01:13 PM   #2
HakenTT
My Ride: 323i with S54
EWS rolling codes got out of sync. Then you pulled the key out waited some time, at this poing ECU and EWS rolled back to the first rolling code, then when you tried again it started but because the battery voltage dropped so low, fuel pump was not getting up to proper pressure, then you accelerated a bit, this made alternator charge more, this stabilised the fuel pressure and engine idled fine.
HakenTT is offline   Reply With Quote
Old 03-25-2013, 10:55 AM   #3
NumbaOneNewb
My Ride: 2003 330CI Silver
Fuel pump
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
