E46 Xi Forum
Old 03-07-2013, 01:41 PM   #1
Dr.frankinstein
My Ride: 01 330xi and more
tie rods?
i have a 2001 330xi and need a tie rod. my question is will tie rods from a 330i fit the same? i dont have alot of money at the moment
Dr.frankinstein is offline   Reply With Quote
Old 03-07-2013, 01:43 PM   #2
SamDoe1
My Ride: 4cyl of fury
No they will not. Tie rods are Xi specific.
Generally speaking, anytime there's an Xi only option, the RWD version won't work.
Old 03-07-2013, 01:49 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
www.realoem.com It has parts numbers. If the numbers are different then they're different for a reason.
Old 03-07-2013, 02:15 PM   #4
Dr.frankinstein
Alright thank you.
Suggestions on where to get them?
Old 03-07-2013, 04:43 PM   #5
SamDoe1
Pelican Parts is my usual go to for OEM parts. OE parts are always super expensive.
Old 03-07-2013, 10:50 PM   #6
Dr.frankinstein
yea but oem seems to be the best way to go sometimes. was just wondering because the un removable outer ball joints can be changed. just wondered if there was a tie rod from a different model that would fit.
Old 03-08-2013, 09:43 AM   #7
SeattleLSB
My Ride: 2003 330XI, 2003 M3
best to replace each for about 120 for each side.
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 03-08-2013, 10:49 AM   #8
e46alfonso
My Ride: 330xi MT, mustang gt
Joe
This.
Meyle tie rods are cheaper but I'd use oem.
http://www.oembimmerparts.com/BMW_E4...rts_s/1913.htm
Old 03-08-2013, 10:50 PM   #9
Dr.frankinstein
what is the difference between the tie rods for the 330i and the 330xi? length of them? does anyone have measurements on them at all?
Old 03-11-2013, 09:10 AM   #10
SamDoe1
Length. I don't have measurements but you can probably search and figure it out.
Or go to the dealership and ask to see both but don't buy from there.
Old 03-11-2013, 10:36 AM   #11
Dr.frankinstein
I have been trying to find measurements but nothing so far
Old 03-11-2013, 12:35 PM   #12
SeattleLSB
I used Lemforder which are the same companies that BMW pays to build the OEM units.
Joe
Old 03-11-2013, 05:59 PM   #13
Dr.frankinstein
I have lemforder tie rods coming. I would still like to know the difference does anyone have old tie rods they can measure
Old 03-29-2013, 02:23 AM   #14
fiv216
My Ride: 2005 325xi
not to thread jack, but if they don't fit do the aftermarket adjustable like hotchki (sp) fit? if not are there aftermarket options
fiv216 is offline   Reply With Quote
Old 03-29-2013, 02:37 AM   #15
drift.mechanic
My Ride: E46 323i
I bought Lemforder OEM inner and putter assemblies with the lock taper washers, lock nuts and taper nut for the outter.
They come pre assembled and ready to rock out of the box, my cost was circa 85$ per assembly (L inner and outter, another 85$ for R inner and outter).
Not going to find a much better seal than that.
Use the Realoem.com tie rod assembly numbers (just below the individual tie rod part numbers).
drift.mechanic is offline   Reply With Quote
