Old 03-07-2013, 05:19 PM   #1
jM2.me
My Ride: BMW
Volute Spring. What is it?
Doing some reasearch on e46 wiring and found something called "Volute Spring" on WDS its part I01002 (E46 WDS here)
As far as I can tell it is connected to K Bus, DDE/DME, I-Bus, multiple restrain system, and finally multi-function steering wheel.
So does anyone know what it is, or what it might be?
jM2.me is offline   Reply With Quote
Old 03-07-2013, 06:57 PM   #2
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
It's a flex cable connecting parts on the moving part of the steering wheel with the rest of the car (airbag, cruise buttons, radio/phone controls and horn.).
scottjoh is offline   Reply With Quote
Old 03-07-2013, 08:18 PM   #3
-fixture-
My Ride: 2004 BMW 325ci
Hope this is the correct one.
-fixture- is offline   Reply With Quote
Old 03-07-2013, 08:23 PM   #4
cyberkaa
My Ride: E46 332i,M3;E30 325i
Correct. It's also known as a clock spring or slip ring.
It allows components that rotate about a central axis to maintain electrical contact with a fixed element without twisting a wiring harness.
On an E46, the volute spring is the slip ring that allows the steering wheel to connect to the harness.
-Kalim
(klx photo studio)
Old 10-09-2016, 12:53 AM   #5
CostiX
My Ride: E46 325
i have a steering wheel with shift paddles (smg gearbox) and i accidentaly got out the volute spring... is there a posibility that i could replace that volute spring with wires ? or is there a method to insert it in the correct order ? thank you (sorry for my english )
CostiX is offline   Reply With Quote
Old 10-09-2016, 03:01 AM   #6
paraklas
My Ride: ESS TS2 320ci
You mean that you unwrapped the ribbon out of the slipring body? if so, it's a pain to put it back together without breaking it. Why don't you pick up a used one and be done with it?
You can't really use wires as they will break with the steering wheel rotating.
Old 10-09-2016, 02:52 PM   #7
CostiX
My Ride: E46 325
yes i unwrapped the ribbon out of the slipring body....i can`t use other ribbon because my steering wheel has the shift paddles .... the other steering wheels don`t have them... i think that i will look for wires and replace the ribbon.... what do you think ?
