Old 08-04-2014, 06:21 AM   #21
James Buntline
My Ride: BMW 540
Ok, I will do the cluster check but first I have to take out the cluster to repair the pixels, maybe I can check the bulb during that operation?. I dont think its the bulbs because I bought this car one week ago and Im sure (almost) that they both were working at that time.
In the left field with CEL light an EML light the light for battery and oil still works during ignition.
It makes me a little bit schizo that I am not sure if these two lights worked when buying the car, concerning the other warnings as airbag I am 100 proof sure.
James Buntline is offline   Reply With Quote
Old 08-04-2014, 08:40 AM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
Not aware that the E46 has issues wit the pixels in the cluster like the E39.
But if you take the cluster out, check for tape or damage to the LED's around the warning light area.
Old 08-04-2014, 10:57 AM   #23
annnnt1
Lol ur car Hates u! That's why it hisses at u
annnnt1 is offline   Reply With Quote
Old 08-04-2014, 11:35 AM   #24
robin325ci
My Ride: Helrot 325Ci
OP you have a european spec car. Mine is Euro spec as well, and I've never seen the EML light come on. Even on my friend's '02 318i the EML light did not come on when we unplugged the MAF.
robin325ci is offline   Reply With Quote
Old 08-04-2014, 09:02 PM   #25
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
Yeah, I was gonna suggest that -- under bright light, I can see on my cluster things that could never light up, like Convertible Top (I have a coupe) or TPMs (optional in '03).
Sicily1918 is offline   Reply With Quote
