Old 03-07-2013, 06:20 PM   #1
keithj8201
My Ride: 2004 325Ci
Car not starting after coolant flush
Hi guys new to this forum and I searched around for awhile but can't find an answer to this problem. I flushed my coolant on my 2004 325Ci following the procedure from this thread
http://www.e46fanatics.com/forum/sho...d.php?t=689618
Now my car is not starting. Can anyone help me. There was a post in that thread about his problem but no one answered it._a_
keithj8201 is offline   Reply With Quote
Old 03-08-2013, 02:35 AM   #2
tinman831
My Ride: M3
What did you unplug?
tinman831 is offline   Reply With Quote
Old 03-08-2013, 04:24 AM   #3
keithj8201
My Ride: 2004 325Ci
Thanks for the reply. Well I also replaced the water pump and thermostat so I unplugged the fan, thermostat, level sensor and radiator outlet switch. I did plug everything back in and when I did the flush the car turned on but after draining it again and refilling and bleeding the system the engine wont turn over and there is a faint clicking sound.
Old 03-08-2013, 04:27 AM   #4
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
Sounds like it might be your battery. How old is it?
HacksawMark is offline   Reply With Quote
Old 03-08-2013, 04:54 AM   #5
keithj8201
My Ride: 2004 325Ci
Hmmm not sure same battery it had since I bought the car 3.5 years ago not sure how long it was in there before I bought it. I know it's not the factory battery though.
Old 03-08-2013, 07:17 AM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I believe some have plugged the connectors into the wrong things before...maybe you did...nothing personal.
So, maybe therm connector is plugged into the exhaust solenoid...or cps. I believe that can be done.
Does sound like battery...a jump would answer that question.
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-08-2013, 08:05 AM   #7
Adionik
My Ride: Bavarian Panzer
Battery is dead or terminals are loose. Check connections and have it tested at Autozone
Adionik is offline   Reply With Quote
Old 03-08-2013, 10:32 AM   #8
keithj8201
My Ride: 2004 325Ci
Thanks everyone for the help. It was my battery. Hooked up my battery charger and a few minutes later she started right up.
