Old 03-07-2013, 07:04 PM   #1
1jbmwe46
My Ride: 2003 e46 330i
e46 jizzabuild
Just wanna share this build with you guys. Had this e46 and thought that this project would be interesting, even though it has been done a thousand times. 1jz swap
ID:	494402   Click image for larger version
ID:	494405   Click image for larger version
ID:	494406   Click image for larger version
ID:	494408   Click image for larger version
ID:	494409   Click image for larger version
ID:	494410   Click image for larger version
ID:	494412   Click image for larger version
ID:	494413   Click image for larger version
ID:	494414   Click image for larger version
ID:	494416   Click image for larger version
1jbmwe46 is offline   Reply With Quote
Old 03-07-2013, 07:57 PM   #2
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
*sub'ing*
E46 Coupe is offline   Reply With Quote
Old 03-07-2013, 08:39 PM   #3
MaverickM3
My Ride: gets badge
Nice project OP.
MaverickM3 is offline   Reply With Quote
Old 03-07-2013, 08:47 PM   #4
emgee
My Ride: 3 pedal 2005 325xi
iin
emgee is offline   Reply With Quote
Old 03-07-2013, 09:03 PM   #5
jerseyzillest
My Ride: 325 CI
I'm in this!
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is offline   Reply With Quote
Old 03-07-2013, 11:10 PM   #6
BMW E465
My Ride: 1dirty5
Mandatory image in any 2jz build thread:
Ah damn just read it's 1jz, lol. Same same
BMW E465 is offline   Reply With Quote
Old 03-08-2013, 02:15 PM   #7
1jbmwe46
Thanks guys
Old 03-08-2013, 02:23 PM   #8
1jbmwe46
I got 8 weeks to finish so pardon the rush pics.
ID:	494520   Click image for larger version
ID:	494521   Click image for larger version
Old 03-08-2013, 02:28 PM   #9
Twin_Turbo_S54
My Ride: M3
nice Project.
which stand alone will you use?
you need some rubber to hook, time to widen Wheel arches.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 03-08-2013, 02:37 PM   #10
1jbmwe46
Originally Posted by Twin_Turbo_S54 View Post
nice Project.
Using AEM.......doing some 19x10.5 in the rear and 19x8.5 in the fron
Old 03-08-2013, 02:39 PM   #11
1jbmwe46
Fuel system almost done......Weldon pump and filters.
ID:	494525   Click image for larger version
Old 03-08-2013, 04:43 PM   #12
BDUB328I
My Ride: bmw 328i S54 sedan (
looking great! intersting pic of the gas pedal also, i didnt know thats how it looked inside
BDUB328I is offline   Reply With Quote
Old 03-08-2013, 04:55 PM   #13
1jbmwe46
Yeah we had to open it to convert the drive by wire to cable
Old 03-09-2013, 05:31 AM   #14
02PRUV
My Ride: E46 M3 Turbo
I didn't bother doing that. I just went to the wrecker and got on E46 6 cylinder cable throttle pedal and cable. They bolt straight in
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 03-09-2013, 09:19 AM   #15
1jbmwe46
kool...I didnt know that. we still dont know how we are gonna make the cluster work.....lol
Old 03-09-2013, 05:16 PM   #16
02PRUV
What are you wanting to get working? Keep the factory ECU in the car, speedo runs off the abs so it will still work, use the BMW water temp sender in the 1j so your water temp gauge works, use the BMW oil pressure switch so you have a working oil pressure light, use the BMW ecu alternator light wire so your alternator light works, use the 1j ECU tachometer output to go into a Dakota digital tachometer box and the output of that into the tachometer input on the BMW ECU.
Things like oil level, water level etc you can just short out to clear those lights. And things like check engine, eml etc you can get the ecu programmed to turn these off.
All of this should work in theory. Im doing it all at the moment with an LS. I'm even going to measure the resistance of the oil temp gauge and get a temp sensor than is the same resistance so I still have the oil temp gauge as well.
Rides:
Old 03-09-2013, 08:21 PM   #17
mike@maximumpsi
My Ride: 02M3T
Those motors seem to fit nicely in the e46 chassis. I saw another 1 or 2jz swapped e46 at a shop in south Florida last year.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 03-09-2013, 08:39 PM   #18
02PRUV
Too bad we can't do this swap in Oz in an E46. We aren't allowed to put in an older engine than the age of the chassis due to emissions laws.
Rides:
Old 03-10-2013, 03:00 PM   #19
1jbmwe46
Will definitely try this and let you know how it turns out.....
Old 03-10-2013, 03:07 PM   #20
1jbmwe46
Fits like a glove!!!
ID:	494779   Click image for larger version
