Old 03-10-2013, 09:02 PM   #21
BMW E465
My Ride: 1dirty5
Originally Posted by 02PRUV View Post
Too bad we can't do this swap in Oz in an E46. We aren't allowed to put in an older engine than the age of the chassis due to emissions laws.
NSW (a state in Oz) has recently introduced some stupid laws whereby I can't put an LS1 in an e36 anymore. Apparently the new engine size cannot exceed 25% extra displacement IIRC
What are the chances of having it certified and rego'd in ACT, Pruv?
Whoops, sorry for the thread highjack! Good luck with the build OP.
BMW E465 is offline   Reply With Quote
Old 03-11-2013, 06:34 AM   #22
02PRUV
My Ride: E46 M3 Turbo
You have to comply with Vsb 14 below:
http://www.infrastructure.gov.au/roa...jan2011_v3.pdf
Going by that multiplier n/a and using the weight of the heaviest sedan model in the range which would be an E36 m3 vert an 1560kg x 5 for n/a you can nearly legally do an 8L engine.
The problem is when wanting to go f/I. The multiplier drops to 3 so you can't do a ls1 turbo.
So yeah an ls1 in an E36 in nsw is legal
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 03-11-2013, 06:54 AM   #23
BMW E465
My Ride: 1dirty5
I thought they changed it?! I remember reading some bulletin from the RTA last year stating otherwise (i'll try to find it)... well damn, this now changes things up. Thanks for the info mate.
Old 03-11-2013, 08:56 AM   #24
SweTurbo
Big Pimpin'
My Ride: 323i -98
use the 1j ECU tachometer output to go into a Dakota digital tachometer box and the output of that into the tachometer input on the BMW ECU.
The tacho works off the can bus coming from the ECU , ecu uses the Crankshaft sensor to output the tacho signal.
Does the Dakota box output a 60-2 signal ? If not you can always fake it with the CAM signal with a 1-1 signal.
In my Link G4 i need to run it on the cam signal(the link fires once per ignition event so i need to run it with a .17 multiplier aswell, running this low however causes the tacho to not drop below 1.3k rpms )
In short : im interested in making my dash work too, unless link has updated their code
Old 03-11-2013, 10:24 AM   #25
1jbmwe46
My Ride: 2003 e46 330i
Decided to go with a Racepak cluster.......gives me more options.
ID:	494908   Click image for larger version
ID:	494909   Click image for larger version
ID:	494910   Click image for larger version
1jbmwe46 is offline   Reply With Quote
Old 03-11-2013, 10:27 AM   #26
1jbmwe46
Ya'll got any info on the Diff setup. Ive been hearing that these diffs cant take any beating not even a little........?
Old 03-11-2013, 10:55 AM   #27
1jbmwe46
Carbon fibre timing belt cover
Old 03-11-2013, 08:17 PM   #28
02PRUV
The dakota digital box it effectively infinately programmable on the output. So you set it to what you want to see on the dash. You have to use the ouput of this box as an input to the factory ecu though. So the dakota box basically becomes your cam sensor. Your input to the dakota box is your aftermarket ecu tach output.
Rides:
Old 03-12-2013, 08:52 AM   #29
SweTurbo
Big Pimpin'
My Ride: 323i -98
Thats awesome
I can then run the cam sensor to my ecu(1-1 signal) , ecu tacho output to dakota box(i can configure the dakota box to accept 6pulses per rpm?) which then feeds the DME as the cam sensor (1-1) , or even use it as a cran sensor(60-2)
If so i might have found the soloution to my rpm problems
Sorry for the threadjack this is an awesome build
Old 03-13-2013, 03:56 AM   #30
danameisgee
My Ride: m3
Hey can you explain how to hook up the cable to the gas pedal plz and were did you get the cable ?
danameisgee is offline   Reply With Quote
Old 03-13-2013, 10:04 AM   #31
1jbmwe46
We got the cable from Race parts Solutions in South Florida. We pulled the pedal out as you can see in my other pics and attached the cable to part that retracts when you depress the pedal........This part is located at the base of the pedal assembly.
Old 03-17-2013, 01:00 PM   #32
1jbmwe46
Piping all done
Old 04-11-2013, 05:59 PM   #33
jonel1225
My Ride: 02 325ci
any new updates?
Untitled
jonel1225 is offline   Reply With Quote
Old 04-20-2013, 08:16 PM   #34
E462j
My Ride: 323ci
I wana Race!
E462j is offline   Reply With Quote
Old 04-20-2013, 08:38 PM   #35
dre8119
My Ride: destroys my wallet
e46 jizzabuild
Please post a vid when this is done...PLEASE!!!!
dre8119 is offline   Reply With Quote
Old 04-22-2013, 05:58 PM   #36
autospeed_01
My Ride: 2000 328Ci
The more that I see these builds with the 1jz and 2jz, the more I question an s54 swap + turbo kit. Sick build!
autospeed_01 is offline   Reply With Quote
Old 04-29-2013, 08:16 PM   #37
cryptonyte
My Ride: 2002 e46
Sorry for the delay fellas been busy with work.........
ID:	503029   Click image for larger version
ID:	503030   Click image for larger version
ID:	503031   Click image for larger version
ID:	503033   Click image for larger version
cryptonyte is offline   Reply With Quote
Old 04-29-2013, 08:25 PM   #38
cryptonyte
My Ride: 2002 e46
SleepR look........Waiting some CCW classic and Bilstein suspension
Old 04-29-2013, 08:26 PM   #39
cryptonyte
My Ride: 2002 e46
sleeper
Old 04-29-2013, 08:36 PM   #40
cryptonyte
My Ride: 2002 e46
Can the Cable throttle pedal from the 2000 323i work in the 2003 330i drive by wire..........I need a cable pedal?
