Old 03-08-2013, 10:37 AM   #1
wcoszhp2003
My Ride: 2003 330i ZHP
Please help, PA Soft 1.4.0 Scanner
So iv exhausted a lot of time and a small amount of resources so far trying to get this all to work with no luck. First off i drive a 2003 330I ZHP and consider myself a pretty smart guy when it comes to doing DIY's for this car and other cars, so i wouldn't be on here asking for help unless i have exhausted all the possibility's i know of to get this working, and i have tried the search button trust me, but anyway, I purchased PA soft 1.4.0 BMW Scanner from xcar360.com and received a month later, I also purchased a 90's-early 2000's windows XP laptop to support the program. When i received the scanner it was fully intact in good condition but the driver disc was broken in half. I went on the forums and found several different forums all directing me to this site www.bmw-scanner.com to download the drivers, which i did. I have followed the instructions that i have found in many different threads to try to apply the drivers that i have downloaded to run the scanner. I also have the scanner program on my computer and that works fine but i just cant get the dam drivers to work to run the device. I have went into device manager and manually tried to search the folders for any proper drivers with no luck. It just says that windows cant find any drivers for this device in the folder. My computer recognizes the device as BMW Scanner V14X too. I just don't seem to have the right drivers or need to modify the drivers for my device.
Any help or suggestions are appreciated.
I am currently in Northeast PA but am moving to Long beach NY in the next 3 weeks. So anyone in either of those areas that could give me hands on help if i cant sort this out would be awesome.
wcoszhp2003 is offline   Reply With Quote
Old 03-09-2013, 02:05 PM   #2
wcoszhp2003
Anyone?
Old 03-09-2013, 04:17 PM   #3
sillieidiot
My Ride: '06 AW 330ci
why did you buy another laptop? or you didn't have one at all? if you had w7 pro, i would just run it under xp mode. that's what i did.
but maybe describe what you did exactly? cause even you say you read the directions and followed it, you might have comprehended it wrong and did something different lol
Old 03-09-2013, 04:33 PM   #4
wcoszhp2003
I bought another laptop because i work on a lot of different cars and i wanted to make it like my "car computer" and have different scanner programs on it. I have vista on my regular laptop. Could I run it on xp mode on there? If so how do I do that? Iv heard about doing that but just never tried to do it.
Old 03-09-2013, 04:55 PM   #5
jamex
My Ride: 2005 325Ci
Go to device manager and start the update driver wizard for the dongle. I'm assuming from here you've been using "Search automatically for updated driver software". DONT.
Instead select "Browse my computer for drivers software". From here you're probably choosing a folder and clicking next. DONT.
Choose "Let me pick from a list of device drivers on my computer". From here I think it will ask you what kind of device from the list, there should be an option for "Other" or something like that. The next window should have a button for "Have disk". Click that shit and NOW point it at your driver folder.
That should get you sorted. Try different copies of the driver if you have to. It should just work.
You may have to have the dongle hooked up to your cars odbII port too, I can't remember.
Good luck.
edit: I don't think XP mode is required to launch and run BMW Scanner. Pretty sure I've got it running on 32bit Windows 7 natively.
jamex is offline   Reply With Quote
Old 03-09-2013, 05:06 PM   #6
wcoszhp2003
Yes, I was choosing the folder and hitting next so hopefully that was my problem. I will try this all again the right way and post back my results. Thanks so much!!
Old 03-09-2013, 05:10 PM   #7
jamex
My Ride: 2005 325Ci
Yeah, its not that you did anything wrong. Windows "should" detect and install the correct drivers the way you tried but I've found sometimes you have to forcefeed down its throat this very specific way and it will yield a different result.
Old 03-09-2013, 05:13 PM   #8
sillieidiot
it's not required for 32bit, but it does for 64bit. i would run it regardless though, just cause it's like a clean install.
Old 03-11-2013, 10:21 PM   #9
wcoszhp2003
Got it working on both my computers. Thanks for all the help!!
Old 03-12-2013, 09:09 AM   #10
SH4DY
My Ride: '04 330Ci
Did you guys have to solder together pins 7 and 8 (k-line) on the usb-obd2 cable? I've seen some threads on this forum and others that say this is a must....
Sent from my PH44100 using Bimmer App
SH4DY is offline   Reply With Quote
Old 03-12-2013, 09:16 AM   #11
jamex
My Ride: 2005 325Ci
I ordered the correct dongle along with PA Soft online and didn't have to modify anything. If you're using some generic usb -> ODB2 cable then it likely requires modification.
edit: felt i should clarify. i did not spend $600 on a dongle + software. if you're willing to spend $50 you're all set.
Old 03-20-2013, 10:12 PM   #12
xcar360
Past Site Sponsor
My Ride: BMW 318i
great answer.....
OBD2ToolBox
xcar360 is offline   Reply With Quote
Old 04-05-2013, 09:55 PM   #13
SH4DY
My Ride: '04 330Ci
Just to update: I soldered the pins together and now it works. Found out the car came with a "smokers package." Interesting...
I downloaded the RomRaider (OpenECU) logger to see what it can read (if anything). I'll update this post tomorrow with what I find out.
Old 04-06-2013, 03:12 AM   #14
sillieidiot
smokers package is when you have a cigarette lighter and ash tray in the front under the sunglass holder. which i think most cars come with lol
Old 05-23-2013, 04:45 PM   #15
kalikidd6600
My Ride: 323i
Angry need help going crazy scanner 1.4.0
Howdy one and all. I have read all 50+ pages plus many on bimmerfest but nothing seems to help. I got a scanner off EBAY for my 2000 323i. It came with a mini disk with everything. I have installed the drivers (shows o bytes used for memory. And the program, first time I connected it it could not read anything, uninstalled. Went to PA Soft and downloaded the trial version went thru and installed that version, Now it says device not ready. I let it sit for a beer break tried it again and still says device not ready. I am using a older dell laptop with XP pro, no anti virus no inter web, I even tried a different cable than came with it. After three days I am about to go insane, set it up on a buddies comp and worked the first time. Any thoughts as to what moronic thing I am doing wrong?
kalikidd6600 is offline   Reply With Quote
Old 05-23-2013, 07:03 PM   #16
jamex
My Ride: 2005 325Ci
you need to actually hook up the scanner to your car to ready the device and get past that screen....otherwise the scanner doesn't get any power. give that a try and report back.
Old 05-23-2013, 07:11 PM   #17
kalikidd6600
My Ride: 323i
I have had it plugged in to the data port under dash, I how ever also found out I need to have the car running for some reason. I tried at post. 1 but get error cannot connect to ike and another error for ews. I took apart the scanner to see if pins 1 & 2 with 7 & 8 were connected and they are but still no ZKE function.
Any thoughts?
Old 05-23-2013, 07:15 PM   #18
kalikidd6600
My Ride: 323i
Have a thought but not sure, my car was built 9/99 and was told maybe the 20 pin cable under hood might be needed. I have went to autozone and they never had any problems but then again I have not had any errors, just tring to tweek my car.
Old 05-23-2013, 07:33 PM   #19
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
You need the 20 connector adapter to use pasoft
tnhl1989 is offline   Reply With Quote
Old 05-23-2013, 07:52 PM   #20
Hornung418
My Ride: '04 MB ZHP
Re: Please help, PA Soft 1.4.0 Scanner
Terra and I have found a way around the 20 pin connection.
Just jump pins 17 - 2 - 20. It should look like this:
Hornung418 is offline   Reply With Quote
1.4.0, dme, pa soft, scanner
