e46 m3 clutch on 330d ZF 5-speed - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-06-2017, 01:56 AM   #1
Ollie74
My Ride: E46 m50b30 turbo
Maybe the thread sounds stupid but, I can't have access to any vehicle.
I'm asking this because I want to fit a Clutch Masters-725 twin clutch-e46 m3 to an 330d ZF 5-speed gearbox.
I know for sure that m3 clutch disc hub diameter is bigger than the one from 330i ZF 5-speed gearbox.
Does anyone know if an e46 m3 clutch would fit on 330d ZF 5-speed input shaft?
Does anyone know which is the 330d clutch disc hub diameter? Or the 330d ZF 5-speed gearbox input shaft diameter?
Thx a lot for any advice in this matter.
M3 clutch disc
Name:	e46 m3 disc.jpg
M3 clutch disc hub measurements
Name:	e 46 m3 disc hub 1.jpg
Name:	e 46 m3 disc hub 2.jpg
330i clutch disc hub measurements
Name:	330i disc hub 1.jpg
Name:	330i disc hub 2.jpg
Ollie74 is offline   Reply With Quote
Old 01-06-2017, 06:10 AM   #2
jd improved
My Ride: charged 330i smg
m57 184ps e46 330d 5spd
Nabenprofil: 28x35-10N
Zähnezahl: 10
Kenngröße: 240B
s54 e46 m3 6spd
Zähnezahl: 10
Kenngröße: 240B
m54 e46 330i 5spd
Nabenprofil: 23x29-10N
Zähnezahl: 10
Kenngröße: 240D
s50 e36 m3
Zähnezahl: 10
Kenngröße: 240D
e46 m3 clutch shuld fit to the 330d 5spd box. Just for my interest what is your plan? Do you want to fit a Diesel Gearbox to an i/m3 motor or do you want to use the twin disc clutch on an Diesel car?
I'm searching for an twindisc clutch (and DMF!!!) setup which holds 1000 Nm and more for a 330d 6spd
jd improved is offline   Reply With Quote
Old 01-06-2017, 07:17 AM   #3
Ollie74
You're my star man.
I have an e46 sedan 330i which in less than 2 weeks will become hmm.. let's say m50b28-30 engine with turbo app. Hope to get aprox 650hp.
M50 engine block, 2,8 cranck, 330i cam shafts, forged pistons & rods, cometic head gasket and ARP studs. My mechanic will keep the double vanos from my 330i engine for this turbo application.
All turbo parts are ready to fit in.
Regarding the clutch&gearbox subject, I'll swap my 330i zf 5-speed gearbox with a 330d ZF 5-speed gearbox which is more resistent. And is just around 50 euro in Romania.
So, this 725 twin clutch which is designated for m3... you can see the pics... according to what you're saying, should fit into 330d gearbox
Just in case, this is my whatsapp +40757038038
Would be much easier for me to chat there and maybe to learn more things from you ref to my project.
I'm more than willing to share this project specifications.. we'll see at the end of spring the results.
Thx a lot for updates jd improved
Sponsored Links
Advertisement
Old 01-06-2017, 09:01 AM   #4
Kyrazh
My Ride: e39
no whatsapp boys! chat here, it's an intresting for alot of us)
Kyrazh is offline   Reply With Quote
Old 01-06-2017, 09:18 AM   #5
Ollie74
When I said I'm more than willing to share this project, I was referring to the forum. Yes, indeed, for me whatsapp would be easier -changing info in real time but, I'll gladly inform everybody ref to my little proj
Old 01-06-2017, 12:14 PM   #6
JakerMacDorey
My Ride: 93 325is
What gear ratios are in the 330D ZF?
JakerMacDorey is offline   Reply With Quote
Old 01-06-2017, 06:36 PM   #7
jd improved
Ok just for your interest and I hope you know that already, the Diesel Engines are sitting in another angle to the chassis. The main bolt pattern is the same on m50 and the e46 Diesels (e60 and e90 3L Diesels have a bigger clutch bell housing) but it is rotated by around 10 deg. Some people has mounted Diesel Gearboxes on petrol cars, as you can see in the picture below, but it is not plug and play.
Old 01-07-2017, 12:06 AM   #8
autospeed_01
My Ride: 2000 328Ci
The benefit of the diesel gearbox to the petrol engine would be, if you're willing to make the engine mounts match the 10 degree change, your engine is rotated for a bigger top mount turbo setup!
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 01-07-2017, 12:16 AM   #9
Mflara20
My Ride: 04 330i
Subscribed!
I'm having issues with my 330i 6 speed transmission and thinking of replacing it with the m3 version. I would consider replacing with a diesel gear box if it easily modified and further benefits over the m3.
Sent from my SM-G930P using Tapatalk
Mflara20 is offline   Reply With Quote
Old 01-07-2017, 02:13 PM   #10
Chibo
My Ride: Nothing
Sure, but what does this do to the oil pickup?
2005 330i ZHP Sedan (Street/Track)
2002 Honda S2000 (Street/Track)
2003 Yamaha R6 (Track/Race)
2007 Aprilia Tuono 1000 (Street/Track)
Chibo is offline   Reply With Quote
Old 01-08-2017, 11:48 PM   #11
autospeed_01
My Ride: 2000 328Ci
Depends how extreme you go. From what I've seen on Swedish forums is the minor rotation from the diesel trans doesn't mess with things too much.. But I'm not speaking from personal experience, just what I've seen.
The pro's at PPF have done this, and I believe they sell the modified components for a proper (worry free) vertical setup.
My Build Thread
Old 01-10-2017, 12:12 PM   #12
jd improved
And they are selling a dry sump oilpan.....
