E46 Xi Forum
Old 04-24-2013, 12:00 PM   #1
Distdiddy
My Ride: '02 325xi
Front axle stuck!! Help!
Front driver side axle is stuck to transmission. Any idea on how to get it out?
Thanks!
Distdiddy is offline   Reply With Quote
Old 04-24-2013, 12:55 PM   #2
Distdiddy
My Ride: '02 325xi
Help?
Old 04-24-2013, 12:57 PM   #3
Russian172
My Ride: e46 sedan e46 m3
Bp blaster ?
Wd40 ?
Unbolt it ?
Russian172 is offline   Reply With Quote
Old 04-24-2013, 01:03 PM   #4
GSherbs
My Ride: 2002 330 xi
stuck to the transmission? you mean the front diff?
You typically need to give it a good whack with a 3lb sledge or the like to overcome the circlip that keeps it secured inside the diff...
What are you trying to accomplish and what have you done so far?
GSherbs is offline   Reply With Quote
Old 04-24-2013, 06:43 PM   #5
Distdiddy
My Ride: '02 325xi
I guess if that's what it's called. Well I'm trying to swap axle because the first one went bad. I'm at the part where I need to take the axle put.
Old 04-25-2013, 08:57 AM   #6
MiniXP
My Ride: 08 335i & 01 325xi
Have you tried getting a prybar or screw driver in between the diff and the axle and prying? Or line up a board with the axle by the diff and hammer on it?
I'm about to do this job tomorrow. Hoping I don't run into this. If you already got it out let me know what you did.
MiniXP is offline   Reply With Quote
Old 04-25-2013, 09:27 PM   #7
bmwporschefan
My Ride: 2001 330xi
What I did was have someone pull on the axle while I took a large screwdriver or punch and gave it a couple of good whacks with a hammer on the lip near where the axle enters the diff.
'01 330xi
bmwporschefan is offline   Reply With Quote
Old 04-26-2013, 04:17 AM   #8
TR4G-
My Ride: '01 325xi, '90 325iC
Same here (minus the extra person): snagged a nice flat tipped punch and whacked it with sledge on the lip and it popped out easily
TR4G- is offline   Reply With Quote
Old 04-26-2013, 08:01 AM   #9
jonnie325xi
My Ride: 2004 325 XI
I use a flat end air chisel on that lip , pops them right out!
jonnie325xi is offline   Reply With Quote
Old 04-27-2013, 05:22 PM   #10
pone
My Ride: 325xit
I'm having trouble getting the new one in. I pulled the circlip off the end and inserted to verify the fit, so I know the only obstruction is the circlip. And I know it needs some force but I'm afraid ill damage something if I wail on it.
pone is offline   Reply With Quote
Old 04-27-2013, 06:26 PM   #11
pone
My Ride: 325xit
****er won't go.....
Old 04-28-2013, 10:30 AM   #12
MiniXP
I don't know if you got it already, but I had to reshape my clip some to get it to fit. I think I deformed it when pulling it off the old axle. This was by far the mostd frustrating part of the job both times I've done it.
Old 05-02-2013, 10:52 PM   #13
pone
My Ride: 325xit
yeah, that's what i ended up doing. reshaped the clip, and it went on really easy. seemed too easy, so i reshaped it again so there was a little more resistance. i figured it wants some force to keep it in place. but it was impossible with the original shape.
Old 05-03-2013, 09:01 AM   #14
MiniXP
Same thing happened to me. It slid in easily and I was like wait was that too easy... but then I couldn't pull it out very easily, and I had heard it snap in, so I figured it was fine.
