E46 Xi Forum
Old 04-27-2013, 05:40 PM   #1
DieselMinded
My Ride: '03 330xi
Any tips for changing water pump?
I have a new pump in route , just preventive maint.
I have the electric fan so i guess i dont need any special tools?
Should i remove the radiator ?
I already have new tstat, cap and expansion tank sitting here as well as 1 gallon bmw antifreeze do i mix it with distilled water? What is the capacity?
Oh yeah i have new serpentine belt coming too
Thanks in advanced
DieselMinded is offline   Reply With Quote
Old 04-27-2013, 05:54 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
DIY has been posted many times, search for it and you will find it. Very simple job with simple tools. No need to remove the radiator.
Old 04-27-2013, 05:58 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Look like you have all the parts.
Takes about 2 gallons of 50/50 mix. But if you don't drain the engine block, it will take about a gallon.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-27-2013, 06:09 PM   #4
DieselMinded
My Ride: '03 330xi
My car has the electric fan so i dont need the special tools correct?
Old 04-27-2013, 06:12 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Just a torx bit to remove the one bolt holding it down. I think T30 is the size.
Old 04-27-2013, 06:32 PM   #6
BMWCaptain
Yes, only mix with distilled.
BMWCaptainE46.com
Old 04-27-2013, 06:34 PM   #7
DieselMinded
My Ride: '03 330xi
i read the diy but they are for the cars with the fan connected to the motor?
Old 04-27-2013, 06:42 PM   #8
BMWCaptain
Same DIY, but no fan clutch to remove and your fan shroud is your electric fan.
BMWCaptainE46.com
Old 04-27-2013, 11:03 PM   #9
DieselMinded
My Ride: '03 330xi
Was my electric fan oem?
Old 04-27-2013, 11:21 PM   #10
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Waterpump is straight forward, buy the all metal pulley and new hardware for the entire operation.
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 04-27-2013, 11:23 PM   #11
SeattleLSB
Tell us more about more mileage as well, perhaps all pulleys are in order,belts and radiator or hoses whole everything is out. I did the block flush on my XI's it was a bit rough but I got it done, just don't lose the block plug like I did.
Old 04-28-2013, 12:50 AM   #12
longtallsally
My Ride: '02 325xi
It's a joke- took me under an hour including filling and burping the system. I didn't put a new expansion tank or anything in, but it really was very easy and only minimally messy. You won't really need any special tools. I thought the tensioner was a hex and not a torx, but I could be wrong. Honestly I got like 5 tools out of the toolbox for this repair.
Be glad you have the electric fan as it makes messing with things on the front of the motor really easy. I think alternator only took about a half hour to replace.
longtallsally is offline   Reply With Quote
Old 04-29-2013, 09:15 AM   #13
BMWCaptain
There is an electric fan on all e46s, but no mechanical fan on the manual transmission cars.
Check Realm.com to see what parts applied to tour model.
BMWCaptainE46.com
Old 04-29-2013, 09:16 AM   #14
BMWCaptain
Check Realoem.com to see what parts applied to your model.
BMWCaptainE46.com
Old 04-29-2013, 10:42 AM   #15
SamDoe1
My Ride: 4cyl of fury
Do you have a manual?
Old 04-29-2013, 11:09 AM   #16
DieselMinded
My Ride: '03 330xi
Yes
Old 04-29-2013, 01:50 PM   #17
SamDoe1
Then you have an electric fan from the factory.
Old 05-02-2013, 09:31 AM   #18
BMWCaptain
Yes, it would be a puller fan behind the radiator.
BMWCaptainE46.com
