Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southeast
Southeast
AR AL GA FL KY LA MS NC SC TN
Old 03-08-2013, 01:30 PM   #1
bimmerican21
My Ride: 2002 BMW 325Ci
Need help!! Very rough idle with loud knocking.
I have a 02 325ci with 156,000 miles on it and it's driving me insane. When I first got it I replaced the water pump with one that has a metal impeller, thermostat, spark plugs, oil filter adapter gasket, and valve cover gasket. It has been idling really rough. Not only does it idle rough, it has a more than occasional knock. But only at idle. At first I thought my coils were bad. Bc at the time I had multiple misfire codes with fuel shut offs. So I acquired Bosch coils. Same problem. Most of my codes are gone tho. The first and only code that has come up so far is p1525 and my scanner says manf. Control vehicle spd. Idle speed control aux inputs.
When I search this code all I see something about the crank position sensor. So I'm really confused. So could it be the disa or iac? I cleaned both with throttle body cleaner while I was replacing the oil filter adapter gasket. And after I had put it all back to together it idle worse than ever. Which was when I replaced my coils. So now I'm super stumped. If someone know Wat else it could be or could actually look at it and give me some advice that would be great.
I'm located in orange park,fl.
Thanks!!
Sent from my PG86100 using Bimmer App
bimmerican21 is offline   Reply With Quote
Old 03-08-2013, 01:45 PM   #2
bimmerican21
And it only gives me that could when I actually have it running. If the car is off but in the on position I have no codes. I probably haven't had it running long enough to have any codes saved.
Old 03-09-2013, 07:21 PM   #3
Viper3812
My Ride: E39 M5, E53 X5
Checked the PCV?
Sent from my MB860 using Bimmer App
Viper3812 is offline   Reply With Quote
Old 03-10-2013, 08:42 PM   #4
VG1134
Old City Bimmer
My Ride: Classifieds
Was it acting up before you did all that work?
VG1134 is offline   Reply With Quote
Old 03-14-2013, 01:19 PM   #5
bimmerican21
Yes it was acting up before. I have another post in the general section and I posted the outcome there. Thanks guys.
