General Off-Topic
Old 03-10-2013, 07:40 AM   #1
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
laptop gurus
i used to build my own desktops, and never, ever, had any kind of failure , so
i have an hp laptop, only about 6 months old
i have an email out to hp now but
yest i got a hard drive imminent failure error
so i ran chkdsk and it found nothing
i then tried to run the hard drive though the hp diagnostic disk test
and it failed the short dst test, whatever that is
it's working fine for now , but, my guess is it's failing and needs to be replaced?
i find it strange that chkdsk would find nothing but hp test it would fail
mmmmmm, hp making money selling disks perhaps?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 03-10-2013, 10:08 AM   #2
Grande D
My Ride: E36 M3
So chkdsk repairs disk permissions? Do you have an external backup? Might want to get a new hard drive and make a copy of your current one- so you can pop it in if your current one fails.
But you probably already thought of that.
However if it's 6 months old, HP should give you a new hard drive I'd think.
It will change your life!
Old 03-10-2013, 10:13 AM   #3
wasp9166
disk permissions?
it checks disk for errors no?
hp said they will send me a new hd, just a pia, now i gota reload everything
i'd have to get an external drive to back up no?
anyhow, hp told me to go into bios and run diag from there, but disk does not show
awaiting their reply
i'm pretty sure this is a wd drive, which i used for builds with no issues, but i see online across the board disk failures on hp laps
why? did they use cheaper wd drives?
Old 03-10-2013, 10:16 AM   #4
wasp9166
btw, i have no windows disc, so, how does that work?
lol, should have just kept building, yet to find a lap that isn't a pos
i hear lenovo might be best bet
Old 03-10-2013, 10:28 AM   #5
Grande D
My Ride: E36 M3
Originally Posted by wasp9166 View Post
disk permissions?
So they will give you the new drive- and have you install it? It's pretty cool that they trust customers to do that.
Right, I think chkdsk does the same thing as Disk Utility Repair Disk (sorry I've been largely out of the PC game for a couple of years). Is there a repair function or something like that listed in chkdsk? I googled and it looks like it has that functionality.
My boss used EaseUS to copy his (Windows 7) drive to an SSD without a problem.
If the copying works how it has for me- you won't need a Windows disk. HP probably sent you those disks if you do need them. They may be called funny things, but one of them probably has a restore option- which usually includes the OS.
I can loan you the hardware you need to copy the disk if HP isn't going to help you on that front. I use this to copy drives.
Hard drive quality had been getting better up until a year or two ago when some disaster (I think the Tsunami?) forced production elsewhere. Prices skyrocketed and quality crashed and burned. Names don't mean what they used to unfortunately.
I hear Lenovo (office/pro laptops) are the best as well.
Old 03-10-2013, 10:30 AM   #6
Spiral Prophet
Über-Geek
Spiral  Prophet's Avatar
My Ride: '01 Topaz Blue 330ci
Send a message via AIM to Spiral  Prophet
just buy a cheap external usb enclosure and clone your current drive to the new drive HP is sending you. Clonezilla is what i tend to use it's free.
It'll take no time and you won't have to reinstall everything or worry about a windows install disc.
Also ChkDsk checks disc sectors and the partition.. The failure message you're getting is probably from the S.M.A.R.T which means hardware failure and which chkdsk does not talk too.
Spiral  Prophet is offline   Reply With Quote
Old 03-10-2013, 11:10 AM   #7
atinybug
My Ride: e92 335i
Not to sound like an ass but getting a HP was your first mistake. They're good for nothing except making printers, but their printers are great. We have a deskjet that's lasted 10+ years. For laptops, buy one made by one of those Taiwanese motherboard manufacturers, like Asus or MSI. I've always used those and have never had any problems with them.
atinybug is offline   Reply With Quote
Old 03-10-2013, 11:13 AM   #8
Iceman00
Banned User
My Ride: E90 6MT
HP should send you a recovery disc if your request one, or you can make one yourself. You'll want to back up your infomation too.
Old 03-10-2013, 11:37 AM   #9
wasp9166
yeah, live and learn on the hp
well, the drive doesn't even show in bios, even after re seat so, they sending me a new one
i'll get back to this later, lunch with the trim
Old 03-10-2013, 01:41 PM   #10
slo323ci
My Ride: 00 323ci
What I'd do, is backup all of your important information you have to an external. Try to create a recovery disk, try to do a disc clone. if the drive isn't too messed up, you will be able to create one. We only use HP's at work(Elite and Pro Series), and I just recently had this happen to me where all other check disks said it was fine, but HP said it was bad. The computer would take forever to load certain things, but would always eventually get to them. I wasn't even able to use Clonezilla on it as the drive was so bad.
slo323ci is offline   Reply With Quote
Old 03-10-2013, 01:54 PM   #11
G3 GFX
My Ride: 528i
Seems like its more a software issue than a Hard Drive issue. There could be a bug causing this, making the computer believe there is something wrong with the HD.... Buy a cheap external and copy your important files over... Once done restore the laptop back to brand new...make sure you install all the latest drivers via the hp website.... This could save you alot of time and trouble. IMO HP isnt worth it, if selling and buying a new laptop is a possibility i would def do that...
G3 GFX is offline   Reply With Quote
Old 03-10-2013, 02:13 PM   #12
Iceman00
Banned User
My Ride: E90 6MT
It's a hardware issue, the BIOS isn't detecting it.
Old 03-10-2013, 05:35 PM   #13
awesomechinz
My Ride: 1999 BMW 323i sedan
If you can get your data then by all means do so, but if you can't, weigh your options and maybe just build your own laptop. MSI sells shells with mobo and you can customize those just like you would a desktop tower.
If you don't feel like building go for an ASUS or a Lenovo U-series.
Check for deals on www.deals2buy.com
They have pretty good deals on Lenovo laptops and those are good quality too.
awesomechinz is offline   Reply With Quote
Old 03-10-2013, 05:51 PM   #14
wasp9166
well, aside from programs i use to keep it clean , i really don't keep much on it, so that's good i guess
i need to tell them i need a recovery disk?
still stumped as to how i load windows onto new drive
or did i miss it
Old 03-10-2013, 05:56 PM   #15
slo323ci
My Ride: 00 323ci
or did i miss it
Recovery disk will have windows on it.
Old 03-10-2013, 06:04 PM   #16
Grande D
My Ride: E36 M3
or did i miss it
If you clone your hard drive using the program I linked you too- Windows and everything else goes with your data. It copies everything.
Old 03-10-2013, 06:19 PM   #17
awesomechinz
Boot from cd drive rather than hard drive
Old 03-10-2013, 06:37 PM   #18
wasp9166
ahh,ok
for what?
that's what i don't get, how can the drive not show in bios, yet the computer, for now, runs fine?
Old 03-10-2013, 06:40 PM   #19
Iceman00
Banned User
My Ride: E90 6MT
OP needs to read online on how to restore computer - there are instructions on the manf. webpage on how to do it.
Old 03-10-2013, 06:41 PM   #20
awesomechinz
ahh,ok
for what?
Post 14: you were stumped on how to load windows on a new drive. When you initially start up the computer you can press like F8 or some key that brings up the "boot from" menu
