General Off-Topic
Old 03-10-2013, 06:41 PM   #21
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
Originally Posted by Iceman00 View Post
OP needs to read online on how to restore computer - there are instructions on the manf. webpage on how to do it.
restore a bad drive?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 03-10-2013, 06:42 PM   #22
wasp9166
Originally Posted by awesomechinz View Post
Post 14: you were stumped on how to load windows on a new drive. When you initially start up the computer you can press like F8 or some key that brings up the "boot from" menu
oh no, i understand that full well, just hard to do with no windows cd
Old 03-10-2013, 06:48 PM   #23
David McMahon
My Ride: '99 E38 740iL
Does the machine start at all? If does then create own Recovery disc then use on new HDD if not then Windows 7 (assuming 7) can be *legally* downloaded and burnt to disc then used on new HDD, as the recovery soloution will also contain a large software build I would use the MS (plain) disc anyway
Link http://www.heidoc.net/joomla/technol...download-links
The HP disk check is hardware and gospel
CheckDisk is Windows built in disk check and is very good at repairing disk software issues (I always run if after a cleanup, incorrect power down etc)
Most Windows 7 era PC's are "7HPx64" Windows 7 Home Premium x64 bit and the direct link is here http://msft.digitalrivercontent.net/win/X17-58997.iso
The rectangular sticker on the bottom of your lappy (possibly under battery) is entered mid way though set up
David McMahon is offline   Reply With Quote
Old 03-10-2013, 06:49 PM   #24
wasp9166
i'm on it now, runs fine, no error messages today
i can create a recovery disc now? blank cds i have are only 800mb
Old 03-10-2013, 06:56 PM   #25
David McMahon
Highly recommend some DVD-R media *Some* recovery solutions work on CD-R but I'd say pop and go grab some DVD-R's if you possibly can will make life easier even if RS does accept CD-R's
Old 03-10-2013, 07:00 PM   #26
David McMahon
Also look in your start menu shortcuts, there should be some HP links that have "recovery" in them. Failing that most OEM's have a .pdf manual with recovery guide (normally) in the back
At this point you have backed up your data right? Not many get the luxury of a failing (rather than dead) disk to get busy backing up!
Old 03-10-2013, 07:02 PM   #27
wasp9166
yes, hp recovery manager , there is
create recovery media
create a backup
think i should do this, and keep using computer while new drive is on way, then, if and when it does finally crap out, i'll be set to go
so i need dvd-r then?
Old 03-10-2013, 07:09 PM   #28
David McMahon
Sometimes it will tell you what is acceptable, the trend is to need bigger (DVD-R or even USB sticks) so I would deffo pop out in your nice motor to any where that stocks good quality DVD-R (of course that's another whole debate!) In a way you might as well use the Lappy until it dies as replacement is on way anyway! (Just create recovery or download the .iso first)
Old 03-10-2013, 07:14 PM   #29
David McMahon
create a backup
Also try to create a factory image type thing, a backup will of course backup but with all the crap you have now, A factory image is like an excuse for a fresh start.
Old 03-10-2013, 07:16 PM   #30
wasp9166
huh?
Old 03-10-2013, 07:19 PM   #31
David McMahon
Sorry typing fast
I would try to create a factory fresh set of discs (you will need multiple DVD-R's and if allowed *many* CD-R's)
Some recovery solutions have the difference between a factory restore set and a backup set (i.e a backup of what you have now)
I always backup data (pics music docs and homework) then use the Factory restore solution. It's a way of having a clear out.
Old 03-10-2013, 07:22 PM   #32
wasp9166
Sorry typing fast
i could restore the lap back to factory but, i'd rather keep using as is , when it craps out it's done anyhow
Old 03-10-2013, 07:24 PM   #33
David McMahon
Are you able to create factory restore discs? Do that and then you are ready (with a PH1 driver) when the new drive turns up.
(Philips Head #1!)
Old 03-10-2013, 07:43 PM   #34
wasp9166
oh yeah, i had the drive out today so i got driver ready,lol
dunno,i'll check it out tomm
but, what if this doesn't crap out before i get the new one, can i copy from old drive to new drive somehow ?
i had an external enclosure for my old desktop , i'd have to look at plug tho
or would it be pointless
Old 03-10-2013, 07:47 PM   #35
David McMahon
You can copy from one to the other, newer connections are SATA so you could get a SATA-To-USB system. I would just backup user files and use factory recovery discs on the new HDD though
Old 03-10-2013, 07:47 PM   #36
Grande D
My Ride: E36 M3
Yes, you can copy the whole drive. Refer to my earlier posts, that's what I was suggesting you do.
It will change your life!
Old 03-10-2013, 07:59 PM   #37
wasp9166
k, missed it ,soz
and it's a hitachi drive btw, i asked them for a wd, see what they say
Old 03-10-2013, 08:03 PM   #38
David McMahon
Good luck and keep us posted, just make sure you have backed up or copied any data on the drive. For example if you use Outlook the database is not in the "home" folders.
Old 03-10-2013, 08:41 PM   #39
Five_seveN
My Ride: rover james
Send a message via AIM to Five_seveN
Originally Posted by atinybug View Post
Not to sound like an ass but getting a HP was your first mistake. They're good for nothing except making printers, but their printers are great. We have a deskjet that's lasted 10+ years. For laptops, buy one made by one of those Taiwanese motherboard manufacturers, like Asus or MSI. I've always used those and have never had any problems with them.
everything this says
Originally Posted by VaderDave View Post
I'm having a hard time imagining any set of responses that ends with anyone expressing admiration for Marshmallow.
Perhaps you should stop responding. It's a no-win for you here. :dunno:
Five_seveN is offline   Reply With Quote
Old 03-10-2013, 09:37 PM   #40
awesomechinz
My Ride: 1999 BMW 323i sedan
k, missed it ,soz
Hitachi drives are oversensitive.. The one in my tosh1ta failed 2 months after we bought the computer... Used western digital.. No problem
awesomechinz is offline   Reply With Quote
