General Off-Topic
Old 03-29-2013, 06:19 PM   #161
David McMahon
My Ride: '99 E38 740iL
Originally Posted by wasp9166 View Post
eh, f the cloning
say i just hold this drive till old one craps out, and pop the ssd in fresh
i would need to buy windows 7 and make sure cd is first in boot order correct?
1, ok does get more life out of it, just make sure you have backed up data, then back it up again, then test it!
2, Nope, use the links I posted above to get a Win7 iso, then you make it legal with your key on bottom of laptop.
3, Yes, but with blank SDD/HDD it should recognise no OS on the new drive and ask for bootable media.
David McMahon is offline   Reply With Quote
Old 03-29-2013, 06:30 PM   #162
slo323ci
My Ride: 00 323ci
Aren't there issues cloning from a standard hard drive to an ssd?
Sent from my SCH-I535 using Bimmer App
slo323ci is offline   Reply With Quote
Old 03-29-2013, 10:20 PM   #163
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
ya lost me on 1 and 2
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 03-30-2013, 06:47 AM   #164
David McMahon
Just saying that yeah you can use the old disk until it craps out, but make sure to backup data.
You won't need to buyWin7 again as you have the COA http://www.google.co.uk/search?q=Win...=1920&bih=1033 already and can use a Win7 install disc to reinstall, you burn the disc yourself from this image http://msft.digitalrivercontent.net/win/X17-58997.iso Or even use your recovery discs if you burnt them before.
Old 03-30-2013, 07:17 AM   #165
wasp9166
you can use any coa?
that iso is the full windows os?
ty for the help btw
Old 03-30-2013, 10:50 AM   #166
David McMahon
Yes that is the ISO for the full version of Windows 7 Home Premium 64-bit (the most common type)
Run the disc with the new SDD and it will prompt you for the license key written on the COA stuck to the bottom of your laptop, pays to get a photo or write the number down to avoid lifting the laptop up mid install.
Old 03-30-2013, 02:18 PM   #167
wasp9166
cool, so boot order is not necc with a new ssd?
Old 03-30-2013, 02:25 PM   #168
David McMahon
Not normally!
Even If it is, should be a case of spamming F12 when booting, which (on most PC's load a boot menu)
Old 03-31-2013, 10:43 AM   #169
wasp9166
i created a dvd from your iso, can i pop it into my existing lap to see if it's legit, or is there no way to tell?
Old 03-31-2013, 11:54 AM   #170
David McMahon
Well you could install W7 on the SSD now, change the HDD for the SDD and run the disc.
Old 03-31-2013, 12:22 PM   #171
wasp9166
yeah, was thinking of that as well
Old 03-31-2013, 12:57 PM   #172
David McMahon
I'd say go for that, if it all works then great, if not then the correct part can be replaced (new is not necessarily good!)
Old 06-27-2013, 06:40 PM   #173
wasp9166
drive finally crapped out today
page fault in non paged area or some sh!t
anyhow, install went fine, until i realized i had no ethernet drivers and couldn't get online to get em
so i called verizon and spent $20 to have my phone used as a mobile tethered via usb
talk about slow, christ, i have heard of people using phone as wifi, fack that
anyhow, up and running, so wanted to say ty for the help bud
