Weird smell come from engine when hot - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 03-10-2013, 01:47 PM   #1
adrian8507
My Ride: E46 325xi 2002
Hello i have a 325xi 02 141xxxx
I get a weird smell from under hood when my car gets hot . Some heads up. I did my VCG around 136xxx
But this smell its not coming from VCG because there is no oil dripping but when i saw smoke was coming out but from the low part of engine passenger side . Any help will be apreciated .something else the smoke is coming all the way down below o2 sensors.
Sent from my SPH-D710BST using Bimmer App
adrian8507 is offline   Reply With Quote
Old 03-10-2013, 02:07 PM   #2
taveet330i
My Ride: Jet Black 2002 330i
When you have a coolant leak and it gets on something hot like the heads, block, or headers, it will boil like water and makes a foul odor when vaporized. Just my experience
[bimmerapp]
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 03-10-2013, 02:21 PM   #3
adrian8507
But the smell is coming all the way from the back of engine and is a smell like rubber and oil at the same it doesnt smell like atifreeze and i recently changed hoses and radiator tank bracket too and my antifreeze its not leaking anymore
Old 03-10-2013, 08:16 PM   #4
White_Knuckles
My Ride: 2003 325xi
Pull your oil cap and look under it for whitish/yellow gel. Your dipstick may show it as well. Water emulsifies as it passes through your crankcase and leaves these deposits. It happens in areas with cold temps and builds up over the winter. It can affect the CCV (crankcase ventilation system) where oil or goo is burning giving off a strange odor noticed in the engine bay. A failing CCV or restricted line can make this worse. A long freeway or higher RPM drive followed by an oil change often corrects this until the next season. Long means a couple hour run to melt the goo out. It works.
Old 03-11-2013, 07:17 AM   #5
Kubica
My Ride: 2003 325xi
Looks like you used a victor reinz gasket? Needs to be replaced again. Check that all valve cover bolts are snug first.
Old 03-11-2013, 08:55 AM   #6
SamDoe1
My Ride: 4cyl of fury
^ Agreed to check that bolts are tightened up and the gasket was aligned properly before putting valve cover on. Victor Reinz is the OEM and is fine to use.
The only thing back there that can leak onto the manifolds is the VCG unless you have a cracked block.
Old 03-11-2013, 09:18 AM   #7
Jesse M
My Ride: 05' ZHP
Over the course of my detailing career I've experienced foul odors when a "rubber treatment" detailing spray is all over the engine bay, but only lasts about a day. Just my .02
Jesse M is offline   Reply With Quote
Old 03-11-2013, 09:53 AM   #8
Kubica
My Ride: 2003 325xi
There was a bad batch of Victor Reinz gaskets that leaked. They used to be fine, but I don't recommend them anymore. Buy OE.
Old 05-23-2013, 08:58 PM   #9
Tobes52
My Ride: 03 325xi
I have a 03 325xi 140.xxx with this same exact problem to a t. I recently did my valve cover gasket too. I still have the same smell from the same exact area, which is only real bad when prolonged higher rpms up hills. Also I've been dabbling with an oil light on and off. What else could it be? Also considering doing valve cover gasket again as to assure properly done..
Tobes52 is offline   Reply With Quote
Old 05-23-2013, 09:04 PM   #10
adrian8507
Re: Weird smell come from engine when hot
I dont think you need to redo VCG again thats from ur CCV . When u do ur oil change try to get a engine flush to clean up ur engine that can help
Sent from my SPH-D710BST using BimmerApp mobile app
Old 05-24-2013, 08:57 AM   #11
jasonbimmer
My Ride: 2001 BMW 330xi
ok a couple of things can smell when engine is hot on the xi
first is VCG.
second is OFHG.
and third which is only on the xi is the passenger drive axle seal. if you are using an aftermarket re-manufactured drive axle thats been machined smaller than OEM, diff fluid can leak out and get on to the exhaust manifold and its a pretty nasty smell.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 05-26-2013, 11:01 PM   #12
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
truth.
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
