Can E-46 driveshaft U-Joints be changed? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 03-10-2013, 02:43 PM   #1
Fred22
My Ride: 01 330Ci
all the BMWs i've owned in the past had so-called non-replaceable driveshaft U-joints. is the E-46 the same? there used to be a cottage industry of artisans who could replace the U-joints and balance an old shaft... otherwise the drive shafts were $1000 plus to replace with new.
what says the Esteemed Forum?
Fred22 is offline   Reply With Quote
Old 03-10-2013, 02:52 PM   #2
pawelgawel
My Ride: 330CI
Non replacable, Unless you cut and weld and ballance..
Not worth the effort unless you do it yourself. Better off buying used.
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 03-10-2013, 03:34 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You don't need that u-joint...
If someone told you did they're probably guessing. If you have a vibration issue, it's giubo (spelled guibo here...aka as the Universal Joint...the flex disk), or it's center support bearing.
Trust me. You could be the second one here that does.
You want to mention your symptoms while you're here?
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 03-10-2013, 09:35 PM   #4
BlaccDiamonds
My Ride: 04 330Ci + 02 4.6is
Sorry to OP for stealing the tread....but dmax...I hear a "clack clack clack" after I shut my car off.....thinking at first maybe loose metal shields or something....but the more I hear it, the more it sounds like a joint or something.
Anything sounds familiar?
BlaccDiamonds is offline   Reply With Quote
Old 03-10-2013, 10:06 PM   #5
dmax
dmax's Avatar
blac...could it be the clicking of a cooling exhaust? That sounds like a fun guessing game worthy of a thread. Use a hose 5' long, 1" diameter or so as a stethoscope and find the sound. I use flexible electrical conduit from HD.
dmax on Facebook
Mangofy your E46!
Old 03-11-2013, 10:28 AM   #6
BlaccDiamonds
DMax...no, I know what a cooling clicking exhaust sounds like...this is more like the sound of the engine "dieseling" as it shuts down...but its not the engine because its coming from underneath the car, or at least the drivers side cuz I can hear it.
The car drives fine by the way...no issues. When I get a chance and the weather is a bit warmer I'm gonna get down there and take a look.
Probably have it on a ramp and have someone shut the car off while I look and listen.
Old 03-11-2013, 03:51 PM   #7
dmax
dmax's Avatar
Blacc...make your own thread about it...and listen to pulleys.
OP...fyi our u-joint is unserviceable. Only reason for it to go bad is if it got a bad kink in it. A driveshaft can be balanced, but without any apparent damage, I doubt it needs to be--the odds are against it anyway. You might need giubo and csb...which you'd also get if you got a new driveshaft.
Only way otherwise driveshaft might be off balance is if csb was done before and shafts weren't marked before they were separated.
dmax on Facebook
Mangofy your E46!
Old 03-19-2013, 05:29 PM   #8
eweis
My Ride: 1999 328i
I was just quoted $350 for a re-man'd driveshaft from Portland so, they're not all that much.
See...you could get down there and replace the flex disc and the center support bearing but, if your CSB is going bad, it may be or perhaps it's probable that your U-joint is bad which is, in turn, causing your CSB to fail. So, if you just replace the flex disc and CSB, you may still have a U-joint problem which will again kill your CSB.
I'm getting a low speed (15-25 mph) groaning, lurching noise as the wheels (and driveshaft) turns. At this point, I'm assuming it's the CSB and/or U-joint that is going out. So, based on my logic above, I'm thinking about simply replacing the entire driveshaft.
eweis is offline   Reply With Quote
