Old 03-10-2013, 05:46 PM   #1
sjacoby112
My Ride: 2002 325ci
Exclamation Help please!
I was just driving home and I started hearing a weird noise, pulled into my driveway and popped the hood. This is what I am hearing, any help would be much appreciated! Sounds like it's coming from right under the oil filter housing. Also, no SES lights or anything came up, car felt fine driving the last little bit home too. Thanks a lot guys.
Video below is my actual car:
sjacoby112 is online now   Reply With Quote
Old 03-10-2013, 05:51 PM   #2
oAllElseFailo
My Ride: LS3 C6
not sure but subbing just in case i hear this in my car - i'd like to hear the problem/resolution
oAllElseFailo is offline   Reply With Quote
Old 03-10-2013, 06:07 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
Sounds like a pulley is going bad or something.
Old 03-10-2013, 06:22 PM   #4
sjacoby112
My Ride: 2002 325ci
i cant even think of what it might be, its super loud it seems right by the belt where i put the camera but i dont really know because of how loud it is
Old 03-10-2013, 06:34 PM   #5
scim459
My Ride: 14 328i, 05 325cic
probably a pulley. check them out asap so they dont seize and leave you standed. should replace all of them while youre in there so you dont have to worry about them. idler, tensioner, and ac tensioner.
scim459 is offline   Reply With Quote
Old 03-10-2013, 07:03 PM   #6
sjacoby112
My Ride: 2002 325ci
so 08/2001 is my production date correct? sorry I'm still learning lol
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
Old 03-10-2013, 07:06 PM   #7
scim459
yes
Old 03-10-2013, 07:09 PM   #8
sjacoby112
My Ride: 2002 325ci
is this what i should order? anything else i would need or is this everything? idler pulley isnt included but im assuming i need that too
http://www.ecstuning.com/BMW-E46-325...elt/ES2593604/
Old 03-10-2013, 09:26 PM   #9
sjacoby112
My Ride: 2002 325ci
i wanna order parts tomorrow if this is whats wrong, anyone wanna verify what im getting?? im going to throw in the idler pulley as well becuase i assume that needs replacing.
Old 03-10-2013, 10:10 PM   #10
ryannel2003
My Ride: '04 Cadillac Deville
My car sounded like that about 6 months back and it turned out to be the water pump. This I knew because I had already replaced all the pulley's and belts and the noise was still there. The bearing on the pump was bad and it sounded nearly identical.
ryannel2003 is offline   Reply With Quote
Old 03-10-2013, 10:41 PM   #11
sjacoby112
My Ride: 2002 325ci
is it a terrible idea to drive it until the parts show up?
Old 03-10-2013, 10:55 PM   #12
ryannel2003
I drove my car from May until September before I replaced the pump with no issues. I don't recommend doing it my way but I don't think it would hurt anything. Just for comparison, here is my noise from my car:
Old 03-10-2013, 11:19 PM   #13
sjacoby112
My Ride: 2002 325ci
so were you good once you replaced the water pump? since in the video you said you were told the water pump was fine? thanks for the replies man!
Old 03-10-2013, 11:31 PM   #14
MJLavelle
My Ride: 2001 BMW 330ci
If cost is at all important to you, then don't go to ECS. Try RMEuropean or BMA parts, or OEMBimmerParts.
Old 03-10-2013, 11:33 PM   #15
ryannel2003
Oh yeah I replaced the water pump and everything is fine. I went with OEM Saleri. $60 from AutohausAz.
Old 03-10-2013, 11:40 PM   #16
sjacoby112
My Ride: 2002 325ci
does this look good pre water pump??
Old 03-11-2013, 12:20 AM   #17
My Ride: Lexus
Sir. You need to buy everything in my cooling link. See my sig. Search my username for a recent pulley thread i did to find out which pulleys you need (that info is also in my cooling thread)
GL!
Old 03-11-2013, 01:09 AM   #18
sjacoby112
My Ride: 2002 325ci
GL!
thanks I checked it out. I placed the order before seeing your post. but I feel like I got everything as far as pulleys and belts go with what I just ordered right?
Old 03-11-2013, 01:13 AM   #19
ryannel2003
Do you have a history of cooling system work on your car? If not it will be a good time to go ahead and replace other necessary items. Water pump, thermostat, upper and lower hoses, expansion tank... stuff like that. Mango's link in his sig has all the necessary parts and the associated numbers.
Old 03-11-2013, 03:17 PM   #20
sjacoby112
My Ride: 2002 325ci
no history. car was previously owned by an older man that was a dentist. so he never had to replace anything on it. but after I do all the pulleys and belts when they show up (hopefully by wednesday) then ill look into ordering the rest of the cooling system. haha I just got wheels/tires/coilovers/tails/LEDs/and more in the past couple weeks. maybe she was upset about all the cosmetics an wanted some maintenance!
engine, loud, noise, pulleys
