Old 03-10-2013, 07:25 PM   #1
220k330
My Ride: 2001 330ci ZSP
bulb out (headlight) icon is coming up....no bulbs are out!
hey guys, ok so the basics, I have a 2001 330ci, 207k miles, halogen bulbs. Friday coming from work (headlights NOT on), the headlight out icon comes on for the driver's side....I go buy a bulb, the old one was burnt, installed it, light went out. So today the icon came back on, got home....all bulbs are burning...tap on the hl assembly....wiggle the bulb...the icon goes out. It then came back on so I go diag'ing it:
I swapped sockets, from side to side and the icon stayed on for the driver's side...so the icon didnt follow the socket....installed all new bulbs (all four), it is still coming on. I checked the fuses and found two fuses for the light module (not really sure what that is....but they were good)
thoughts? what else to check?
thanks guys!
220k330 is offline   Reply With Quote
Old 03-10-2013, 07:39 PM   #2
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Have you checked the corner lights?
Sent from my ADR6425LVW using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 03-10-2013, 07:54 PM   #3
220k330
good point. I just went out and checked it, all lights were working and the icon was out.....next time the aticon comes on i will check the side light. BUT --- the icon comes on when my hl switch is in the off position (doesnt have auto) and in that position the running light is not on, the only bulb that is on is the daytimes running light, (the inner bulb in the hl assem) it has me stumped...and annoyed!
Old 03-10-2013, 08:17 PM   #4
220k330
and by the way guys, if anyone puts this post together with my other one about crossing the battery cables, this happened BEFORE i did that, the icon came on when i was driving to the Saab
Old 03-11-2013, 10:26 AM   #5
220k330
where is the bulb out sensor located for the headlights?
Old 03-11-2013, 10:35 AM   #6
lcoleman
My Ride: '79 Massey Ferguson
I believe it just measures resistance in the circuit, ie no sensor.
Old 03-11-2013, 10:40 AM   #7
220k330
got ya....that is really odd....any other ideas?
Old 03-11-2013, 10:47 AM   #8
nineeight9898
My Ride: 2000 BMW 323Ci
Check your license plate bulbs. Same thing happened to me. Took me awhile to figure it out!
nineeight9898 is offline   Reply With Quote
Old 03-11-2013, 10:52 AM   #9
220k330
i thought of that last night...all the bulbs are working...all of'em....I may swap out the turn signal bulbs just to be sure....
Old 03-11-2013, 11:03 AM   #10
GolfingDuck
My Ride: 540 & 330Ci M Sport
Check the earth for that side's lights.
GolfingDuck is offline   Reply With Quote
Old 03-11-2013, 11:20 AM   #11
220k330
check the earth?
Old 03-11-2013, 11:23 AM   #12
lcoleman
The ground, to those of us on this side of the pond. You can use a voltmeter, or trace the wires. I think it's on the inner fender somewhere.
Old 03-11-2013, 11:32 AM   #13
220k330
OH roger!!! ha!!!! Well, if they weren't grounded, they wouldn't work, right? Or am I having a stupid moment -- which I may add I have had a few of the last few days!!!!!
Old 03-11-2013, 12:34 PM   #14
jdstrickland
My Ride: '94 325iC & '00 323i
Look inside the connectors of the lights to see if there is any signs of them being burnt. The corner lights are also turn signals, so this would explain why the fault indicatore comes on even if the light switch is off.
If you replaced the corner lights with LEDs, this is a problem. Or, it could be a problem. If you replaced a bulb with a non-standard bulb, this could also be a problem. If the bulb socket is corroded, this could be a problem.
Old 03-11-2013, 12:52 PM   #15
220k330
yea, those are all good points...all the bulbs are stock, I swapped sockets from side to side and the warning stayed on the drivers side. (icon didnt follow the socket) new bulbs (h7 GE's) all four (inner and outter in the hl assembly) I know mis-matched bulbs can cause the icon to come on (or new and used) the last thing to check is to pull the turn signal bulbs and check them, maybe swap those sockets (if they are swap-able <-- is swap-able a word? )
