Old 03-12-2013, 11:46 AM   #1
dwsounddesign
My Ride: 2002 BMW 330xi
Cool Oil Pan Gasket HELP! small leak
Does anyone know how much in labor it costs to do the replacement if I supply the oil pan gasket? I have a small leak, and want to get it done soon. I already done the VCG, and I've already checked and it's not leaking anymore. Today I had the car lifted and found the other source to the the pan.....great!
dwsounddesign is offline   Reply With Quote
Old 03-12-2013, 11:48 AM   #2
My Ride: Lexus
If you are sure it's the pan, then labor is around $500-$1000.
Old 03-12-2013, 11:50 AM   #3
dwsounddesign
is that at a euro indie shop? or BMW dealer price?
Old 03-12-2013, 11:52 AM   #4
My Ride: Lexus
indy shop. dealer would be a lot more. the engine has to be supported and the subframe lowered. many things need to be detached. i'd address the oil pump nut while you're in there.
Old 03-12-2013, 11:57 AM   #5
dwsounddesign
when i removed the bottom engine splash cover, it was alot of oil. which i believe was from the VCG cause when it began to leak I waited almost a month to actually change it. I monitor my oil levels much more now. But at least I don't have the burning oil smell anymore... I used to have 6-9inch diameters of oil in the mornings from the VCG leaks, but after that repair it's now 2-4 inch puddles. small but still bothers me...
Old 03-12-2013, 11:58 AM   #6
briangl92
My Ride: VQ37VHR
Dealers charger $1200ish.
I did my OPG and it took 2 days.
briangl92 is offline   Reply With Quote
Old 03-12-2013, 12:04 PM   #7
dwsounddesign
I know my mechanic at my shop allows me to help with repairs...Maybe because of the process, we can both work on it at the same time. Kill the hourly down a tad
Old 03-12-2013, 12:04 PM   #8
Dave1027
My Ride: '06 IR zhp coupe
Remove aluminum belly brace. It's only six bolts for the subframe and motor mounts. Need to use an engine brace or hoist. Disconnect the steering guibo. That's one small bolt. That's it. Not hard at all. Just lower the subframe than you have complete access to the pan.
Old 03-12-2013, 12:06 PM   #9
My Ride: Lexus
Easier said than done. I've done the job three times.
Old 03-12-2013, 12:34 PM   #10
dwsounddesign
How Long Does it take to do?
Old 03-12-2013, 12:37 PM   #11
My Ride: Lexus
first time i did it, it took 12-13 hours. i can probably do it in 10 now? i work efficiently but carefully . you'll want to have a helper for the heavy bits as the subframe can be downright awkward to realign especially when you have 3,200 lbs of car above you
Old 03-12-2013, 12:49 PM   #12
trizzuth
My Ride: 234k, 16yr old B3AST
HA, but then you're forgetting to mention the 23 bolts that hold the pan in that are a PAIN in the ASS to remove and reinstall! that is like the worst part of this entire thing.
trizzuth is offline   Reply With Quote
Old 03-12-2013, 12:54 PM   #13
My Ride: Lexus
oh yeah. that will tire you out like a dog. the subframe has to be dropped really low to comfortably access the center ones. the torque on the subframe bolts is also another body killer as well as torquing down the late model reinforcement plate. two stage torque...
Old 03-12-2013, 01:24 PM   #14
GCoop
My Ride: '04 325xi
Guys.... he has an XI. Whole front subrame and front diff need to be dropped........
Its a bear. I have been able to stave off my leaking XI oil pan for over a year now. I re-torqued as many of the bolts as I could reach (16 or so). If you do it bring the engine up to operating temp first before trying to re-torque and be gentle. You don't want to strip any.
GCoop is offline   Reply With Quote
Old 03-12-2013, 01:27 PM   #15
My Ride: Lexus
yeah i'm sure there's extra complexity with the XI front diff but i didn't want to say anything i wasn't sure of. thanks for the clarifcation
Old 03-12-2013, 01:42 PM   #16
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
I haven't seen it mentioned yet but are you sure it's the OPG and not the OFHG? The oil filter housing gasket is a well known leaker and as it drips down (left/driver side of block only) it makes it appear that it's the OPG. If there is no evidence of a leak on the pass/right side that it's likely just the < $10 OFH gasket and a simple DIY job to replace.
You can check inbetween PS reservoir and throttle body/intake manifold and maybe see if you can see through to the block where the OFH gasket will likely leak
B is offline   Reply With Quote
Old 03-12-2013, 01:47 PM   #17
Dave1027
The XI front diff aside, what's so hard about raising the subframe into place? It was a simple process. I did it with a floor jack in a few minutes.
Old 03-12-2013, 01:51 PM   #18
My Ride: Lexus
yeah that's why i told the op if he's sure. sometimes other stuff can leak giving false impression. +1
every situation is different depending on what you removed/didn't remove. i did it on a lift so standing doesn't give you the same leverage as if your back is on the ground. it's more awkward to wrestle the subframe that way
Old 03-12-2013, 02:06 PM   #19
asma123
My Ride: E70x5 m3conv m3coupe
My front subframe was damaged. my mechanic charged me only $100 to put in the new one!! It's not really too hard just the hard part is supporting the engine properly while you're working on it
asma123 is offline   Reply With Quote
Old 03-12-2013, 03:54 PM   #20
FrodoTBaggin
My Ride: 2004 325i
Got mine done for.$415 labor only but its not an XI....I supplied parts/oil.
FrodoTBaggin is offline   Reply With Quote
