Old 03-12-2013, 04:55 PM   #21
FrodoTBaggin
My Ride: 2004 325i
My post was incredibly unhelpful.
FrodoTBaggin is offline   Reply With Quote
Old 03-12-2013, 04:56 PM   #22
My Ride: Lexus
lol. labor in kentucky sounds like a bargain
Old 03-12-2013, 05:08 PM   #23
FrodoTBaggin
My Ride: 2004 325i
Like most employers in 'tucky, I think most places aren't offering dental which leads to lower overall costs.
(Native Iowan)
Old 03-12-2013, 05:40 PM   #24
330iPilot
My Ride: Titanium Silver 330i
first time i did it, it took 12-13 hours. i can probably do it in 10 now? i work efficiently but carefully . you'll want to have a helper for the heavy bits as the subframe can be downright awkward to realign especially when you have 3,200 lbs of car above you
Man, you guys suck! First time I did my oil pan gasket, it took me 9 hours and I did the fuel filter, engine mounts, LCA's and CA bushings too! Of course it helped that I had a four post lift.
330iPilot is offline   Reply With Quote
Old 03-12-2013, 05:45 PM   #25
My Ride: Lexus
so did i but i have to clean and inspect everything!
Old 03-12-2013, 05:46 PM   #26
BMWespresso
My Ride: 2005 325CI
Got mine done for.$415 labor only but its not an XI....I supplied parts/oil.
yeap got a quote 5 hours at $80, indy shop, mine is starting to leak at 85K miles
BMWespresso is offline   Reply With Quote
Old 03-12-2013, 05:48 PM   #27
FrodoTBaggin
My Ride: 2004 325i
Jeebus, did.that even make.sense? I'm leaving.
Old 03-12-2013, 06:00 PM   #28
330iPilot
Hey! I cleaned stuff!
Old 03-13-2013, 12:13 AM   #29
dwsounddesign
My Ride: 2002 BMW 330xi
The thing is I didn't clean up the skid plate when I took it off. All I saw was resided oil. Most of it looked old from the VCG oil that I changed previously. I wiped most of the oil off but my stains are coming from dead center of engine. small spots nothing bigger than about 2 to 6 inches diameter of oil over 12 hours of it sitting over night
dwsounddesign is offline   Reply With Quote
Old 03-13-2013, 02:32 AM   #30
My Ride: Lexus
that's kind of a lot. that's usually the oil filter housing since oil sits inside of it. the oil should drip beyond the edge of the oil pan so it shouldn't leak that much overnight. Look down with a flashlight next to the oil filter housing. if the waffle section is wet with oil, its your housing gasket
Old 03-13-2013, 10:14 AM   #31
dwsounddesign
I also like to mention that I experimented while car was running in same spot for almost a hour and I had no drips come from it. It seems to only leak when the car is shut off...
Old 03-13-2013, 10:25 AM   #32
My Ride: Lexus
you change your oil filter housing gasket yet? and was it done carefully? i recently had to redo mine due to the tiniest leftover piece of the factory gasket i failed to remove when i did my initial OFHG replacement. the tiniest little black spec that became hardened and stuck to the block caused a leak
Old 03-13-2013, 10:33 AM   #33
dwsounddesign
no it wasn't changed in my possession but i don't think it was ever changed my car has so many miles and I think it's tiime to do all the gaskets....hitting 200K time to get sh*t done.
Old 03-13-2013, 10:36 AM   #34
My Ride: Lexus
do the ofhg first. it's simple enough to do. remove alternator to do it properly. this is not something you want to rush or half-ass
Old 03-13-2013, 09:14 PM   #35
wacuna
My Ride: BMW 323i
My OPG was leaking a bit... I check the bolts and some where a little loose. I tied them up and leak fixed. My cas has almost 170,000 miles...
wacuna is offline   Reply With Quote
Old 03-13-2013, 10:12 PM   #36
wildirish317
My Ride: 2004 325Ci vert
Got a quote today for opg. 4.5 hours labor @ $85/hr, plus $36.58 for the gasket, plus 7 qts of oil @ $6.75/qt (??). Total quote $466.33, plus tax and shop charges.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 03-13-2013, 11:04 PM   #37
330iPilot
That's pretty cheap!
Old 03-13-2013, 11:22 PM   #38
aggies
My Ride: BMW 330Ci
Getting my OPG replaced as we speak at a local repair shop.
Attached is a copy of my receipt
aggies is offline   Reply With Quote
Old 03-14-2013, 01:28 AM   #39
My Ride: Lexus
oil stabilizer. dafuq?
Old 03-14-2013, 12:35 PM   #40
aggies
My Ride: BMW 330Ci
