Old 03-21-2013, 09:13 AM   #61
Nateweav
My Ride: 2001 330Xi
Originally Posted by Mango View Post
yeah i'm sure there's extra complexity with the XI front diff but i didn't want to say anything i wasn't sure of. thanks for the clarifcation
Mine is an xi and the front diff doesn't cause that much problem. Once you have the subframe and steering rack out of the way you just remove the 4 bolts holding the diff on. Pretty simple really.
Nateweav is offline   Reply With Quote
Old 03-21-2013, 09:52 AM   #62
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
I'm going to keep an eye on this. My '04 330xi just hit 121,212 miles this morning. I've replace the VCG, OFHG, VANOS tube, and the oil separator drain tube. The oil pan gasket figures to be next in line, but it looks like such a PITA, I'm going to wait to take it to the shop. It's also time for some new engine mounts and another CV joint, so this may be a good time to make an appointment.
What else should I have them look at when they're down there? Oil pump nut?
What I've learned so far:
  • don't start working on the car unless you have a ride to the parts shop.
  • whatever you're doing, Mango's guide is probably right.
  • the Bentley manual skips steps. LOTS of them. Don't tear your hair out when the next step makes no sense.
NCLee is offline   Reply With Quote
Old 03-21-2013, 09:56 AM   #63
My Ride: Lexus
The oil pan nut is just a simple off simple on procedure. Nothing to look at. If its tight, replace it. If it's loose, replace it. Same deal.
On an automatic 330 though, the chances are quite low it'll fall off. Tends to happen in manuals since the engine sees redline more often and the "special" harmonics of the 330 crank damper tends to vibrate it loose if you hang around 6k often.
Mine was super tight when I removed it and I have an increased rev limiter and see it often. So go figure
Old 03-21-2013, 10:37 AM   #64
NCLee
My Ride: 2004 330xi
Sounds good. Thanks!
Old 03-21-2013, 10:37 AM   #65
My Ride: Lexus
go with bimmerworld pre-drilled nut w/ wire tie. don't reinstall a plain nut
Old 03-21-2013, 12:44 PM   #66
Nateweav
My Ride: 2001 330Xi
Here is the link:
http://store.bimmerworld.com/categor...ipts=1&x=0&y=0
I have an e46 330xi auto. Didn't replace it. Prolly still have the one I bought if someone wants it. PM me. First one gets it. (if i can find it... )
Old 04-15-2013, 12:21 PM   #67
dwsounddesign
My Ride: 2002 BMW 330xi
Idk if it's the oil pan now.....I cleaned the bottm off, but what strangely happens (and I experimented) is that the oil only leaks when I turn the car off. I had it run in my driveway for about 20minutes, and not a single drip, turn it off, and theres like dime size amounts after 20-30 minutes. I repeated this step like 3 times.
dwsounddesign is offline   Reply With Quote
Old 04-15-2013, 12:28 PM   #68
NumbaOneNewb
My Ride: 2003 330CI Silver
dear god. yet another mystery issue on our cars. I'm starting to see it plague members on here. What if its contagious? we are all doomed! Crap, should I think about selling? no, wait, I can't. I'm already in this too much. Must man up! you guys are starting to scare me
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-15-2013, 12:33 PM   #69
dwsounddesign
haha it's all good, I'm just gonna have BMW look at it. no big deal. It's not a huge leak, but I always keep my eye on the dipstick (no h0m0)
Old 05-08-2013, 05:42 PM   #70
dwsounddesign
Oil Pan Gasket HELP! small leak
Yay! OFHG. Not Oil Pan. My leak is fixed
Old 10-01-2014, 09:14 AM   #71
99magna
My Ride: 2to4
Originally Posted by aggies View Post
Getting my OPG replaced as we speak at a local repair shop.
Attached is a copy of my receipt
That is good prices , can you tell me the name and address of that repair shop. Thanks
99magna is offline   Reply With Quote
