'01 325i auto poor power, excessive fuel consumption - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-12-2013, 12:44 PM   #21
AK65
My Ride: '01 325i auto
OK, I'm back from out of town and driving on the way back from the airport (freeway driving), I noticed the following. At about 100km/h (65mph), the revs are just over 2000. If I want to accelerate on fairly flat stretch of road, I press on the accelerator. After a very quick initial pick up in revs, the revs start to DROP! All that happens is more throttle just makes the consumption meter hit max, with no appreciable increase in power at all, if anything, a drop in revs and speed. I also notice a vibration seeming to be coming from the rear diff - could this be the guibo? Could this be a power sucker?
I'm just not convinced the behaviour this car is normal, despite what the mechanics say. It's a very subtle problem that doesn't really show itself if you thrash the car at higher revs....
I am racking my brain, but apart from valve timing, which I am assured it isn't, what else could cause a drop in revs when you open the throttle? In the old days when I had a student car, it would be like the vacuum advance wasn't working. I've checked the timing advance though, and it's perfect.
I'm determined to get to the bottom of this though.
And also by the way, I've now got a logged code P0365, which is an exhaust cam sensor (I think). I don't know if that has anything to do with anything.
AK65 is offline   Reply With Quote
Old 04-12-2013, 06:20 PM   #22
lcoleman
My Ride: '79 Massey Ferguson
Did you test the cats yet?
Old 04-13-2013, 12:18 AM   #23
AK65
When the car was in for diagnostics, they had all types of probes in the tailpipe, and they said the cats were fine. Car has no problem revving, when it gets there. Just crappy torque from 1-3.5 k. Most prevalent in higher gears. It had a boggy stumble at 1.5k in the lower gears which is much better now. But overall, it's performing at about 75% imo.
Old 04-13-2013, 05:28 AM   #24
jfoj
My Ride: 330CiC, M5, X5, E93
Auto trans torque converter bad??
There is a one way clutch for the stator in the torque converter. If the one way clutch goes back, the stator will act as it is not there. The stall speed of the converter will be much lower. Usually this means after 2500-3500 RPM the engine will seem fine, but for dead stop to under 2500 car will feel like a dog.
Highway cruise should feel ok, but acceleration will be be poor until about 3000-3500 RPM.
This will also impact fuel economy.
Any decent mechanic that know what to look for should be able to identify this, however, you may live in a culture of manual transmissions so it may be hard for the average mechanic to pinpoint.
Old 04-13-2013, 07:38 AM   #25
jfoj
Just tested this out in my wife's E46 Vert.
Put trans in Sport Mode, start car out in 2nd gear by manually shifting into 2nd gear.
Jump on the throttle from a dead stop and watch the tachometer and see if it jumps up and stays around 2200-2500 RPM before car really starts to move and pick up speed.
If the tach does not jump up to at least 2000 RPM and hang there for a short period until the car moves fast enough for the revs to climb, then likely the stator sprag in the torque converter is free wheeling in both directions?
Old 04-13-2013, 09:20 AM   #26
NumbaOneNewb
My Ride: 2003 330CI Silver
Hold up. Stop throwing money at the car and tell that mechanic to stop hustling you. I just had a friend have this happen. I told him the chances that both o2s no matter how old they are will show as both having failed or faulty, is almost 0. Thats like getting 2 flat tires at the same time. If your mechanic is replacing parts based on the error codes, then he needs to be replaced.
The reason why you're still showing as lean is more air than fuel is being deposited in combustion chamber. The reason why is your pre cat o2s are wondering why the maf is lying to it, trying to tell that there's less air being drawn in than there really is. You need to check your intake tubing, the rubber part going from after the maf to the throttle body. It can't be just inspected correctly unless removed. Doesn't cost much but that's your problem
Sent from my SPH-L710 using Bimmer App
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 04-13-2013, 09:23 AM   #27
NumbaOneNewb
On top of that, everybody that i flashed the euro tune to their ecu told me they notice right away a huge difference from US tune. After updating his car, he told me he felt nothing. I jumped in his car and sure enough, sitting in passenger seat it didn't have that feeling my car has. We knew before the flash he had this big gash right after the maf sensor. I told him get that replaced and thats got to be the reason his car didn't feel fast. He was also showing misfiring codes prior to the flash
Old 04-15-2013, 02:17 PM   #28
AK65
Hi
Thought it best to replace both O2 sensors because the one was faulty, and the other had a short on the heater circuit, and got fouled up.
I used the Bosch replacement sensors, which weren't that expensive..
Fuel trim is fine now. No more lean codes.
@jfoj, I tried your test in 2nd gear, and the revs jumped to 2000 pretty much immediately. The highway drop in revs@ 65 and the 1500 rpm sudden drop revs at about 20 mph still persist. I'm tempted to set the valve timing myself. Like I said before, both torque and power are way below spec. 180Nm and 112kW at 6000rpm, are woeful. Also, car seems to perform better when cold. I've also checked for air leaks, haven't found any as yet.
Another point to note is as we are moving towards winter, the engine has started and cut out twice on cold starts on early mornings. So I'll continue to check for air leaks...
Sent from my GT-I9300 using Bimmer App
Old 09-28-2015, 06:54 AM   #29
andreosmith
My Ride: 2002 325ci
Unhappy Help please!
So I recently changed the plugs in my 2002 325ci, changed the oil and put in some seafoam to clean out the engine. Car ran fine then I took it to the car wash. I went to restart it and all of a sudden rough idle, stalling and almost no throttle response when in drive.
Could water have gotten in somewhere. Did I use too much seafoam? The CEL was on and the code read P0080 " Exhaust Valve Control Solenoid Circuit High B1". Does BMW call this something else.
Does anyone know what the issue could be or how to diagnose? Please help. Im new to fixing the car myself and would rather skip a tow to the shop and shop prices. Thanks!
andreosmith is offline   Reply With Quote
Old 11-11-2015, 12:39 AM   #30
m5runner
My Ride: BMW 535i & ///M3
Sounds like you have a ton of carbon buildup. Allow it to burn off and you should be fine
m5runner is offline   Reply With Quote
