Old 03-13-2013, 10:13 AM   #1
patwhite330ci
My Ride: 2003 BMW 330ci
E46 M54 Valve Cover Replacement
There are a lot of posts about how to replace the valve cover gasket, but not a whole lot on how to replace the entire valve cover. Anyone have any help they can offer?
patwhite330ci is offline   Reply With Quote
Old 03-13-2013, 12:16 PM   #2
Chris C
My Ride: 2001 325Ci
You can use www.realoem.com to determine the part number for your car's valve cover. IIRC you have to take off the valve cover to replace the gasket. Perhaps you can stop at that point and replace the cover. I wish you luck.
Chris C is offline   Reply With Quote
Old 03-13-2013, 12:22 PM   #3
lcoleman
My Ride: '79 Massey Ferguson
There is no additional step if you can do the gasket. Same procedure. Make sure to get new grommets.
Old 03-13-2013, 12:31 PM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
If you recall correctly? What other method of replacing the gasket do you recall that does not involve taking off the valve cover?
advice, diy, m54, valve cover, valve cover gasket
