6MT to 5MT swap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 03-13-2013, 10:44 PM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
6MT to 5MT swap
Right now, trying to decide on what to do with my track car. I've heard of people swapping in a non-M 5MT to save weight. AND...I like the fact that replacement units and consumables seem to be cheaper and plentiful.
I think the hydraulics are the same and everything bolts up except for the driveshaft.
Anyone have some more info? I did search and couldn't find anything.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 03-14-2013, 08:07 PM   #2
illestminimike
My Ride: Project Drama
This would be sick. I think you'll find better help on m3forum.net
Old 03-14-2013, 08:12 PM   #3
ANREC330
My Ride: C6 Vette & M3
I think I remember seeing someone use an e36 M 5speed tranny. I could be wrong though.
ANREC330 is offline   Reply With Quote
Old 03-14-2013, 08:17 PM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
That's the same as the e46 non m 5 speed trans
Old 03-15-2013, 04:33 PM   #5
bigjae1976
bigjae1976's Avatar
I guess the only big question is the driveshaft. I'd like to see if an OE part fits before I go custom.
Old 03-15-2013, 04:55 PM   #6
jhaurimn
My Ride: 01' 330ci
Ive definitely heard of it being done, so it's very possible. The 5 speeds are more durable as well
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 03-16-2013, 05:21 AM   #7
TerraPhantm
My Ride: M3 & ZHP
Maybe a 330i driveshaft -- depends on whether or not the E46 M3 diff is longer
Old 03-16-2013, 10:43 AM   #8
bigjae1976
bigjae1976's Avatar
I know the M3 diff is 40mm closer to the front of the car vs a non-M.
Driveshaft lengths from realOEM
330 5Sp 1550mm
M3 1404mm
So the M3 6MT is 146mm shorter, 40mm of that being the difference in diff location. Which means the 6SP tranny (looks like M and non-M 6MT gearboxes are the same length) 106mm closer to the rear of the car.
So I would need a 1510mm long driveshaft assuming the center bearing is in the same location.
Other lengths...
330 auto 1403mm
330 6Sp 1444mm
330 GM5 1358mm
Basically I guess my only choice is to buy a 5MT driveshaft and shorten the rear portion by 40mm?
The major hydraulic pieces are the same except for the hard line from the rubber hose to the slave and the bracket. The input shaft bearing, flywheel bolts, dowel pin are the same part #'s.
The only other differences in part numbers is the clutch disc, pressure plate, throwout bearing, and flywheel.
So this is my theory. I keep the M3 hydraulics. I swap the flywheel, pressure plate, clutch disc and throwout bearing. Swap shifters. Bolt up the trans and then install a custom driveshaft with the rear portion shortened by 40mm.
Old 03-16-2013, 11:09 AM   #9
bigjae1976
bigjae1976's Avatar
The getrag 420g (M3) is supposed to be 23.5 lbs heavier than the ZF320.
Old 03-16-2013, 11:13 AM   #10
bigjae1976
bigjae1976's Avatar
Yeah...found the answer here...
http://forums.bimmerforums.com/forum...-swap-question
Old 03-18-2013, 08:54 PM   #11
YGOSLO
My Ride: 03 CarbonSchwartz M3
When I read the title my first thought was, why the heck would you do that. Makes sense now. Good luck. Smart move!!
Full Black Interior For Sale
2003.5 Carbon Black/Imola Red ///M3 Coupe: Stock
2003 SVT Ford Mustang Cobra: Not Stock
YGOSLO is offline   Reply With Quote
Old 03-19-2013, 07:21 AM   #12
JohnBlaze
My Ride: Black Sunshine
23 pounds isn't that great of an amount to save, why not do 4.10 LSD instead?
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 03-19-2013, 01:42 PM   #13
bigjae1976
bigjae1976's Avatar
I could do both!
Old 03-19-2013, 02:51 PM   #14
JohnBlaze
yeah, that would definitely be a screamer if you did. Are you going to drive the car to the track or do you trailer?
If you did 4.10's with a 5speed your max speed would be around 145 mph in 5th redlined
Old 03-19-2013, 05:09 PM   #15
vaio76109
My Ride: Race Cars
Bimmerworld can source you the correct driveshaft, I think it's about $600. You can also save a ton of weight off the 6 speed clutch and flywheel, in the realm of 25lbs. You'll also need a different trans cross brace, I'm pretty sure(99%) it's one from a non-M E46 5 speed.
vaio76109 is offline   Reply With Quote
Old 03-19-2013, 07:34 PM   #16
bigjae1976
bigjae1976's Avatar
I think most are using US spec E36 M3 5sp with the ZF320 box. Which I think is also used o. The E46 330.
I would trailer if I were doing the 4.10 and 5sp.
Old 03-19-2013, 07:54 PM   #17
secono330ci
My Ride: 04' 330ci/15' A3 TDI
I'm all in for saving weight, but the getrag feels so much nicer. I keep hearing the 5 spd is stronger, but I'd like to see what the values are for both.
You could always do a carbon drive shaft to save weight
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
