E46 Convertible
Old 03-14-2013, 04:59 PM   #1
4BUCK
My Ride: '01 A4 1.8TQM
Top stuck...suspect CVM wires 13/14
Top gets stuck midway through opening/closing just like everyone else!
I followed the troubleshooting tutorial and here's what I found:
I tested continuity among all the pins at the CVM. 9/18, 8/17, 7/16 all make a beep. The rest of the tests from the guide show a number in the 400s, except for 13/14. I'm assuming that means there's no continuity between 13/14 (Cowl Unlocked Sensor). I tested with the top half open - not sure if this matters.
I cut open the harness in the top, just above the drivers side window, expecting to see a broken wire or two where most people have resolved this issue. My Green/White (13) and Brown/Yellow (14) look fine - they aren't broken.
Do you think 13 and/or 14 are broken somewhere else? If so, where do you think another breakage point might be?
Do you think it's possible 13 and/or 14 are broken in that spot but the break is inside the wire itself (not visible)?
Do you think this means the Cowl Unlocked Sensor (S145) is broken?
I was thinking of running a wire from the CVM number 13 and/or 14 and splicing it into the harness past the last bend to the same wire. Presumably, if it's just a wire that's broken, the top would work after bypassing the broken wire. Just don't want to splice wires without getting some feedback first.
THANKS!
4BUCK is offline   Reply With Quote
Old 03-14-2013, 07:47 PM   #2
taylor192
My Ride: 2003.5 M3
You could remove the cover on the latches to test each wire.
Sent from my Nexus 7 using Bimmer App
Old 03-14-2013, 10:09 PM   #3
4BUCK
Could you expand on that? What latches? Thanks.
Old 03-14-2013, 10:40 PM   #4
taylor192
My Ride: 2003.5 M3
The cowl latches that the wires go to.
Old 03-15-2013, 04:13 PM   #5
4BUCK
From what I've read, it's difficult to remove the cowl trim to expose the Hall Sensor.
So, as a first resort, I'm going to run a "jumper" wire straight from the CVM pins 13 and 14 all the way past the last bend in the top - as far toward the windshield as possible - and see if it's just the wires that are broken.
I'll update with results...
Old 03-16-2013, 07:07 PM   #6
4BUCK
Fixed!
I chose to run a jumper wire from just past the CVM to just past the last bend in the top nearest the windshield. I randomly started with wire 13 and low and behold, it worked! This meant wire 13 was broken. Not wanting to run a wire the full length of the harness, I tried removing a 6" section of wire 13 at the last bend in the top near the windshield (where most people's convertible top harness's break), but it didn't work. This meant that my wire 13 had broken somewhere else. When trying to put the top up, it would stop just after the top would start to come out of the trunk. So, I figured the break was near the trunk - impossible for me to splice at that location, just too tight and dark.
I ended up running a new wire from the last bend in the top nearest the windshield, all the way along the harness, and splice it back into wire 13 just a couple inches past the CVM. The challenge was running the wire without it getting in the way of the top's operation. In the C-pillar, behind the dog flaps, the harness disappears into the hinge. I couldn't run my wire exactly the same as the harness because of this. Once I got to the hinge, I had to run it a different route for a few inches and ultimately back to the harness and then into the rear seat. My concern was the new wire getting in the way of the top's operation. Since the final stage of the top going into the trunk doesn't allow for a good view of what's going on, I made extra sure to tape the wire down so it wouldn't get in the way.
Time will tell how long the wire holds up. I really hope it doesn't get snagged, ripped, or in the way somehow. On the bright side, I now know how to fix it! All in all, I'm delighted that I fixed the problem and my top works again, but perhaps more rewarding is the fact that I finally figured out what the problem was.
Couldn't have done it without this forum.
Old 03-17-2013, 10:55 AM   #7
dknightd
My Ride: 2002 330 cic
dknightd is offline   Reply With Quote
Old 04-20-2014, 08:08 AM   #8
shift4inc
I had a similar problem. The break in the wires were not at the first bend in the roof near the windshield as many others have had. I had to remove a few panels and a small metal wire channel cover on the top mechanism to access the break. There was a very distinct bend in the harness just beyond the metal cover. I took a chance and cut the harness open there and low and behold a broken green and white wire.
2004 330Ci Vert
shift4inc is offline   Reply With Quote
Old 04-20-2014, 11:55 AM   #9
taylor192
My Ride: 2003.5 M3
Originally Posted by shift4inc View Post
Attachment 554598
2004 330Ci Vert
Double check you left enough slack for the hydraulic lines. Your lines look in good shape, yet if you moved them slightly while reinstalling the metal cover then you risk having the metal cover pinch the hydraulic lines if there's not enough slack.
Old 04-20-2014, 10:19 PM   #10
shift4inc
I will, thanks for the tip!
2004 330Ci Vert
Old 05-28-2016, 07:25 AM   #11
Manza
My Ride: E46 330Ci SMG
Great posts! I found my broken wire in that higher pivot point, was easy to fix (only fixed the broken one).
A repair kit has been mentioned, can anyone advise where to get it from?
Thanks!
Manza is offline   Reply With Quote
