#41 | |
#42 |
I did this. it's a direct fit depending on what year model you car is. When I ordered mine it was from an 00 M5 because of the airbag system being a single stage it was compatible with my car. No coding. I see you went with the 3 series wheel. I chose the m5 prefacelift wheel because of the slightly larger diameter. it feels great with my sedan btw if anyone needed an opinion.
![]() Last edited by JasonSmithed; 03-18-2013 at 01:15 AM. |
#43 | |
#44 |
yeah i just figured i'd throw in my knowledge from personal experience since OP said e39 m sport wheel. Referring to your problem if you are wanting to go from steering wheel with no buttons to a wheel with buttons you would have to retrofit it to have the buttons be operational. otherwise you can just not use the buttons or if you just like the e39 msport/m5 wheel the e36 M3 steering wheel is without buttons and has the same design.
#45 | |
Before 09/1999 -- You need a new airbag module and have to recode it for dual stage air bags. 09/1999 - 06/2000 -- You have the right module, but it still needs to be recoded for dual stage air bags 06/2000 and newer: You have dual stage airbags already and the M3 wheel is a direct swap. Buttons... I don't believe it requires coding, but it does require a little bit of wiring http://forum.e46fanatics.com/showthread.php?t=544160 Last edited by TerraPhantm; 03-18-2013 at 02:03 AM. |
#46 |
Thank You
