Old 03-31-2013, 09:41 PM   #21
andynb
My Ride: e46 m3
Originally Posted by InDiGlOM3 View Post
By the way just so its clear. Its the little copper connectors on the end of each wire that is inside the white connector that plugs into jumper box. They are weak and provide no spring action in them to push against tabs in the jumper box. They are also weak dielectirc grease is a bad idea because the connectors are so weak you could possible made a barrier of grease between contacts.
Sent from my EVO using Bimmer App
I believe you're right. I actually read the resistance at each pin and everything was good but that doesn't mean it's making a good connection to the box. The same cheap connectors are used the aem side too. I think im going to replace the jumper harness and if that doesn't solve it replace the main harness between the jumper box and aem.
andynb is offline   Reply With Quote
Old 03-31-2013, 11:23 PM   #22
zac5
My Ride: Turbo M3
thanks for the input guys. please keep us updated OP
zac5 is offline   Reply With Quote
Old 04-01-2013, 02:59 AM   #23
xbass
My Ride: E46 M3 HPF stage 2.5
the same situation happened to my HPF 2.5. More unfortunately, one of my jumper harness pins is burnt... I'll sent ems/jumper box/harness to HPF today, let em check the log and see hat happened. Thanks for all your post, it did helps.
xbass is offline   Reply With Quote
Old 04-01-2013, 07:11 AM   #24
InDiGlOM3
My Ride: HPF M3 stg 2.5
That's what happened to me, bad continuity creates heat.
Old 04-01-2013, 11:18 PM   #25
andynb
My Ride: e46 m3
Problem fixed. InDiGIOM3 was correct it was the small jumper plug, repaired it and the car runs perfect.
Old 04-02-2013, 08:26 AM   #26
InDiGlOM3
Awesome.
Old 04-20-2013, 11:50 AM   #27
xbass
I sourced better connectors just have not got to replacing them all.
Would you please give me the web link or brand/type of this better connector? Many thanks
