Old 03-14-2013, 10:01 PM   #1
Henraye
My Ride: 2001 330Ci
Exclamation Help por favor!
Hey guys, I'm gonna swap in a 5 speed tranny in my 01 330ci during spring break. I had a question though. Im swapping in a 250g from a 04 325ci and i was wondering what drive shaft i would need for this to work? Would i get the driveshaft realoem says is for my car. Or would i get a driveshaft that realoem says would fit the 04 325? TIA and any advice is much appreciated!
-Henry
Henraye is offline   Reply With Quote
Old 03-14-2013, 10:19 PM   #2
Iceman00
Banned User
My Ride: E90 6MT
250G is a 325 trans and has a lower torque rating than your 330i transmission - You can do it, but I'd try to find the right transmission so you don't have to go through the process of finding a new driveshaft and shifter etc.
Old 03-16-2013, 07:07 PM   #3
lszlszx
My Ride: 1.8T, XC70
I like your spanglish! Good luck with the swap, please post an update, at some point I plan to do this, too.
Here are some links on the swap.
http://forum.e46fanatics.com/showthread.php?t=901286
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-25-2013, 04:25 PM   #4
Henraye
My Ride: 2001 330Ci
Ahh okay thank you! I found the right trans, trying to find the a 330 manual drive shaft at the moment.
Old 03-25-2013, 04:26 PM   #5
Henraye
My Ride: 2001 330Ci
Haha took spanish in high school
Will do, thanks for the link!
250g, 320z, 5 speed swap, drive shaft
