Rating:
Display Modes |
#41 | |
My Ride: E46 332i,M3;E30 325i
-Kalim
(klx photo studio) ![]() M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings |
#42 |
Yes, the M3 one uses 12 bolts vs. 8.
Two extra bolts brace the control arm bushings. The other two bolts brace the control arm ball joints.
-Kalim
#43 |
My Ride: M3 & 323Ci (sold)
I don't see why you'd want to use it. the reinforcement is where the CA bushings mount.
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#44 |
Platinum Plus Quality
It's amazing how much more reinforcement the M car gets. Balljoint and CAB. That is awesome. Shows you how much room there is for flex in the chassis. Maybe the Z4M doesn't need/use the extra stiffening points because that body is much stiffer to begin with? Just a theory.
Terra, what would you suggest we could possibly use from the Z4M? Control arm geometry is the same, as you say... we're thinking outside the box here!
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#45 |
Weagle Weagle
#46 |
I don't know that it requires it. I think Terra said the Z4M uses this plate despite using ZHP control arms.
#47 |
Weagle Weagle
#48 |
Like I said, it uses ZHP control arms which means it can't use the M3 bushings unless the Z4M has its own brackets w/ holes that use non-M bushings (which would mean WE could use those brackets) but i doubt it. i think it uses standard non-M bushings. not sure?!
#49 | ||
Edit: Okay here's what I found so far. z4 non-M front suspension = e46 non-m front suspension. Same control arms/bushings, same spindles, same tie rods, same subframe. This tells me that you can likely swap the entire Z4M front suspension to an e46 and the geometry would likely be correct. Last edited by TerraPhantm; 03-15-2013 at 11:47 AM. |
#50 | |
Seems there may be something there... part# 31107838575 http://www.zhpmafia.com/forums/showt...ffset-bushings! http://www.ecstuning.com/BMW-Z4-M_Ro...hings/ES48907/ Thoughts, terra?
#51 |
Seems like there might be something to that bushing. Would caster alone account for a steering feel difference?
And I'm not sure why the shock wouldn't impact steering feel at least a little bit. Doesn't the shock keep the lower suspension where it's supposed to be via the kingpin? I have a hard time believing BMW wouldn't have simply used the E46 m3 or CSL kingpin and control arms if the geometry was appropriate and the shock mounting style had no impact on feel or handling. Seems like a lot of R&D for no reason otherwise. |
#52 | |
anyways I am really curious about the Z4M bushings. I'm curious what the final caster results in
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 03-15-2013 at 12:08 PM. |
#53 |
OK here's a peak at the E9X M3 front strut:
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 03-15-2013 at 12:13 PM. |
#54 |
Well most Japanese cars have a lot more front overhang and front weight than BMWs. And most companies aren't as anal as BMW with getting the steering feel right. Most reviews of the z4m claim the "new" shock mounting style saves weight and sharpens steering response.
#55 | |
Oh well. Wonder if Meyle makes a Z4M bushing replica. or i'll look into the OE bushings w/ brackets
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 03-15-2013 at 12:21 PM. |
#56 |
The z4m bushing might fit in the non-m lollipop. Both are 66mm
#57 | |
you think the caster will be fine?
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 03-15-2013 at 12:26 PM. |
#58 |
Hard to say. It is possible that the only reason the z4m has such an offset bushing is to correct the caster since the kingpin/spindle/whatever you want to call it is different. I doubt it will cause any interference either way, but maybe it would look off?
Were E36 M offset and non-M centered bushings interchangeable? If so, these are probably fine too. One of these days I would like to see M control arms side by side with non-M arms. If they are interchangeable, then maybe ZHP arms plus z4m bushing would give similar improvements? Last edited by TerraPhantm; 03-15-2013 at 12:35 PM. |
#59 | |
http://www.turnermotorsport.com/p-19...r-m-coupe.aspx
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 03-15-2013 at 12:35 PM. |
#60 | |
Weagle Weagle
http://en.wikipedia.org/wiki/Caster_angle Last edited by WDE46; 03-15-2013 at 01:50 PM. |
| Tags |
| control arm bushing, plate, reinforcement, subframe |
