Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 03-15-2013, 01:57 PM   #61
My Ride: Lexus
Originally Posted by WDE46 View Post
Caster is pretty important to steering feel. It effectively adjusts mechanical trail. That's what makes your wheels turn back to center. The strut influences both caster and camber.
http://en.wikipedia.org/wiki/Caster_angle
Nobody ever disputed that. That wasn't the discussion
Old 03-15-2013, 01:57 PM   #62
Dave1027
My Ride: '06 IR zhp coupe
Be advised that going with offset CABs to get more caster will also reduce the camber a little. That might be a good thing though.
Old 03-15-2013, 01:58 PM   #63
My Ride: Lexus
Yeah I'm going to get Vorshlag plates anyway then caster can be whatever
Old 03-15-2013, 02:04 PM   #64
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by Mango View Post
I'm not sure I believe the strut mounting method affects steering feel.
The statement above is what confused me. Were you guys talking about the physical mounting hardware, not the location?
Old 03-15-2013, 02:05 PM   #65
My Ride: Lexus
We were talking about the way the strut mounts on the spindle of the E36 vs E46 vs E85 and how it affects steering feel, if at all.
Old 03-15-2013, 02:20 PM   #66
My Ride: Lexus
Terra: on E46 front suspension refinement vs E36 according to BMW:
"The steering knuckles are press fit into the strut tubes which reduces the tolerances of the front suspension geometry."
The E9X uses the same design. I think it's just to save space. Steering feel, IMO, is going to come from the steering rack design/rigidity, pump effort, balljoint stiffness, chassis stiffness, bushing stiffness, alignment (caster), tire/wheel combination, low unsprung mass, and tierod balljoint location on the front spindle<--probably one of the biggest factors. Not trying to start a war, just my opinion based on observation and reading of suspension tech articles over the years.
Just for fun:
E36:
E46:
E85 Z4M:
E46 M3:
E9X M3:
Old 03-15-2013, 02:26 PM   #67
Zell
Zell's Avatar
My Ride: so turbo wow
Think because it has that puck that it can support lifting without bending?
Old 03-15-2013, 02:40 PM   #68
TerraPhantm
My Ride: M3 & ZHP
I've been lifting my m3 with that puck since I got it. I think the main lifting point is right under it.
Old 03-15-2013, 02:40 PM   #69
ImolaSix
My Ride: '02 330Ci M-sport
The other side of the puck makes contact with the subframe....I think.
ImolaSix is offline   Reply With Quote
Old 03-15-2013, 02:42 PM   #70
My Ride: Lexus
I would upgrade to this for that reason alone (puck) but I'd need an oil extractor
Old 03-15-2013, 02:44 PM   #71
ImolaSix
I still don't understand why BMW removed the center jack point from the non M.
Old 03-15-2013, 02:46 PM   #72
cyberkaa
My Ride: E46 332i,M3;E30 325i
Correct.
-Kalim
(klx photo studio)
Old 03-15-2013, 03:04 PM   #73
TerraPhantm
My Ride: M3 & ZHP
Just for fun:
E36:
E46:
E85 Z4M:
E46 M3:
E9X M3:
Well why did they bother switching it then? That's the part I'm not getting. They deliberately switched to the E46 style, and then the z4m goes back to e36 style mounting. Especially when the z4 non-M has the exact same suspension as the e46 non-M. And both the e36 and z4m just happen to have better steering feedback than the E46.
E9x I'll excuse because its front suspension is closer to the e39 than anything else. A lot more changed than e36->e46
Old 03-15-2013, 03:11 PM   #74
Stinger9
My Ride: '04 330Ci
That's what the mad russian has always said:
http://m3.madrussian.net/diy_jacking.shtml
Old 03-15-2013, 03:12 PM   #75
My Ride: Lexus
I think the single balljoint/control arm style is just being phased out. that's all. expect the newer Z cars to probably have dual link setups just like the 1M, M3, and everything else. More compact, efficient, and allows more flexibility both literally and technically. it does appear to be more complex though and likely costly especially when everything up front has to be aluminum nowadays. Parts have to be larger to achieve the same strength vs. steel so there's less room. Trickery!
F30 dual-link setup: (typical on many newer BMWs and other cars. Even the E39 is similar)
Old 03-15-2013, 03:49 PM   #76
TerraPhantm
My Ride: M3 & ZHP
^ that doesn't have anything to do with the e46 m3 -> z4m change though. Here's why I think there has to be something to it
Almost everything on the z4M was lifted from an M3 or CSL. Same engine, same brakes, same diff, same rear suspension. It is only the front suspension that changed dramatically. Track width is still the same. Wheel offsets are the same. So I'm perplexed by the motivation to change the shock mounting style if it doesn't save room or make handing or response better.
Old 03-15-2013, 03:52 PM   #77
Zell
Zell's Avatar
Dang, I am gonna find a used reinforcement plate then. That makes lifting MUCH easier.
Old 03-15-2013, 04:21 PM   #78
My Ride: Lexus
I think you're assuming that every change from the E46 to Z4M has to=improved steering feel. The chassis of the E85 coupe is a hell of a lot more rigid torsionally than the E46 coupe so that right there should increase handling/steering feel alone. The car is also lighter and lower.
Still not convinced that road feel or steering feed back has anything to do with the way the strut attaches. The strut simply rotates on top through a bearing and is the backbone of the mcpherson strut system. If you mean more vibration, then maybe i could understand since there's more of the strut body screwed/attached to the spindle?
Is there any documentation on this from BMW in the way of technical literature or otherwise? Of course I could be wrong, but just not seeing it how the strut attachment at the bottom alone corresponds to steering feel. If we use that logic, then I would think the 1M would have poorer feel than a Z4M or E36 M
Old 03-15-2013, 04:36 PM   #79
Grande D
My Ride: E36 M3
Is the M3 plate made out of steel?
It will change your life!
Old 03-15-2013, 04:45 PM   #80
My Ride: Lexus
Should be aluminum
control arm bushing, plate, reinforcement, subframe
