Old 03-15-2013, 02:25 PM   #1
Grendelsbane
My Ride: M3
Can someone confirm my understanding of HID foglights
Ok...yes I have done some searching, but am still kind of confused.
My understanding is that the stock OEM HID headlights are 4500K.
If I just use one of those upgrade HID conversions on the foglights...will it cause glare to other drivers? I have read that that housing wouldn't properly focus the light to where it needed to go. Is this correct?
Finally, if I get something like this http://www.ebay.com/itm/140736301115...84.m1423.l2649 where its built in? Would that "fix" any unwanted spread of from the bulb?
My goal is to put out more light, but not blind anybody. Also if I can get the lights to all match that would be cool.
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Mishimoto Aluminum Radiator / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune
Grendelsbane is offline   Reply With Quote
Old 03-16-2013, 04:53 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yes, it will create a ton of glare. ANY hid kit in a halogen housing will do that and also give you worse light output due to the beam pattern.
The ebay link you posted is the same crap, same exact fog light that your m3 comes with but it is of an insanely cheaper material that will have it lense burn up even with a regular halogen bulb (as me how I know, TWICE).
If you really want hids in your fog lights you will need a good quality ballast (not a cheap one from the ebay link which will probably cause a million problems), a wire harness and PROJECTOR fog lights.
Old 03-16-2013, 09:46 AM   #3
Grendelsbane
My Ride: M3
Thanks Solidjake! I think I will pass on that mod then. Seems to defeat the purpose of the fogs.
[EDIT]
Before I totally give up on this mod...is there any fog with link that you can recommend that will not blind people and project more light?
Old 03-16-2013, 03:22 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Aftermarket projector fog lights suck. Only thing I recommend is this
http://e46fanatics.com/forum/showpos...7&postcount=21
Old 03-24-2013, 04:53 AM   #5
bernie21614
My Ride: 01 330i
I have HID in my regular fog light housing and they work great. I want the light to spread out as much as possible and it does so without blinding incoming cars. I'll post some pics of them and where they cutout at.
bernie21614 is offline   Reply With Quote
