///M3 Forum
Old 03-15-2013, 05:37 PM   #1
YYCBMW
My Ride: 2003 M3 Convertible
OBD2 Diagnostic software that works on newer windows?
I've been searching, but with no luck. Anyone know a diagnostic software that works on newer windows or Mac (Vista, Windows 7, or Mac OS X)? Everything I've been able to find or read about on a form is for Windows XP which I don't have on any computer anymore.
I really want to play around with the OEM features that are mentioned in the owners manual without having to pay an arm and a leg to have them turned off and on at a shop.
Thanks for the help!
YYCBMW is offline   Reply With Quote
Old 03-15-2013, 06:09 PM   #2
grkm3
My Ride: Money Pit
Send a message via AIM to grkm3
Have you tried running it in Windows XP mode?
http://www.microsoft.com/windows/vir.../download.aspx
SOLD
03 Steel Gray M3 - Imola Red Interior - SMGII - Premium - HK Sound
Mods: VFE SC Stage 2, SS Ceramic Coated Stepped Headers, S-Pipe, X-Pipe, TMS Subframe Reinforcement, KWV2 Coilovers, TMS Camber Plates, Powerflex RTAB's, Rogue RSM's, ZCP F/R brakes
Coming Soon: Open to suggestions
grkm3 is offline   Reply With Quote
Old 03-16-2013, 06:01 AM   #3
quick99si
My Ride: 2004 M3 6MT
It very likely won't work in XP mode, nor in virtual machines unfortunately. There is a lot of network interfacing, particularly in DIS which already runs in an emulated environment, and is very sensitive to any non-standard installations unfortunately. I know of one local guy running it on Windows 8 + USB, but it is very finicky at the moment (some modules can't be read and connectivity issues)
I always suggest picking up an old laptop, throwing XP on it, and using a serial connection as opposed to USB.
And OP, if you were in the USA, I would offer to sell you my turn-key setup and avoid the installation headaches. Even better, if you are ever near Chicago, I'll gladly help you configure or change any features that you would like.
quick99si is offline   Reply With Quote
Old 03-16-2013, 06:56 AM   #4
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
It can be made to run on the various versions of Windows. The instructions are there on the site inside several threads. There are a couple of turn-key threads also.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 03-19-2013, 04:39 PM   #5
YYCBMW
Thanks everyone.
I think I have a line on a laptop running XP but it likely doesn't have a serial com port. I've had decent luck with USB com ports in the past but they definitely can be finicky.
Stupid question but what is a "turn key" Setup? I'll have to look into that a bit more.
Old 03-20-2013, 09:16 PM   #6
turbo_f22_pilot
"TURN-KEY" means ready to go, all you have to do is port the program / image over to the device and launch it.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
