Sponsored by BAVSOUND
Old 03-15-2013, 08:54 PM   #1
Tony94
My Ride: 03 325i
Low volume after installing an aftermarket radio
Hello everyone, so I have a BMW 2003 325i and I got the radio finally installed today. It is a Sony radio from bestbuy, and I installed it with Metra Amp integration wiring harness. Everything seems fine although the volume is very low, need to turn it up to like 40 plus it seems like the sound is only coming out of the front left speaker. Any suggestions?
Also where should the wiring harness hide, because I wan't able to push in the radio unit completely inside.
A newbie person here, any help is appreciated.
Tony94 is offline   Reply With Quote
Old 03-15-2013, 09:15 PM   #2
limpiabota809
My Ride: 330 XI
Did you add aftermarket amp?
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 03-15-2013, 09:17 PM   #3
Tony94
My Ride: 03 325i
Well all I can say is that I have used this wiring harness and connect it to the aftermarket harness thats it
Old 03-15-2013, 09:49 PM   #4
lamsv
My Ride: 2001 325iT
I think that is the wrong harness? I believe you need Metra 70-8590.
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 03-15-2013, 09:59 PM   #5
Tony94
My Ride: 03 325i
The one above won't work?
Old 03-15-2013, 10:30 PM   #6
lamsv
My Ride: 2001 325iT
I just remember seeing a thread some where that stated that the amp needs a high level input, not a low level input that the RCA's provide. From what I've read, the OEM amp (HK or non-HK) requires a 10volt or so input. Most aftermarket decks have a RCA output in the 2-5 range, far below what will work with the factory amp.
Old 03-15-2013, 10:37 PM   #7
Tony94
My Ride: 03 325i
So if I put the other harness all of my speakers will work with decent sound?
Old 03-15-2013, 11:00 PM   #8
lamsv
My Ride: 2001 325iT
I can't say with absolute certainty, but I believe the Metra 70-8590 will probably solve your problem. Search that harness model number on this site, and you should find the information you need.
Old 03-15-2013, 11:09 PM   #9
Tony94
My Ride: 03 325i
Thanks for your reply, might try some other solutions first since already bought 2 sets of wires which don't seem to work
Old 03-15-2013, 11:57 PM   #10
limpiabota809
My Ride: 330 XI
The one you use is no good...it doesn't send sound to all the speakers you need the other one posted
Old 03-16-2013, 10:03 AM   #11
markusmarkus
My Ride: 2001 330Ci
The OEM head unit outputs are balanced differential. The amp's inputs are probably line level inputs which are unbalanced. You need an LOC converter.
Old 03-16-2013, 11:31 AM   #12
ccaudio1
My Ride: 330i
are all the speakers working? including the sub. i assume you have the HK system since you bought the harness with the rca
ccaudio1 is offline   Reply With Quote
Old 03-16-2013, 11:56 AM   #13
ccaudio1
My Ride: 330i
Incorrect, it is low level input to the OEM amp. The signal is Balanced Differential.
but from what i can remember the output voltage of the OEM radio is higher most of the aftermarket HU. i know alpine, clarion, pioneer has hight output around 4v.
Old 03-17-2013, 09:28 AM   #14
markusmarkus
My Ride: 2001 330Ci
Lets meet half-way! "The signals between the OEM head unit and the OEM amp are balanced differential."
Worx for me!
Old 03-19-2013, 08:25 AM   #15
Tony94
My Ride: 03 325i
Well now I got all of the speakers working + the sub by combining the wires together but the volume still low need someway to connect the head unit with amp
