Sponsored by BAVSOUND
Old 03-15-2013, 11:09 PM   #1
Dmacmilitant
My Ride: 2003 M3
Full BSW setup in an 03 M3
Im ready to buy the BSW stage 1 speaker package amd the subwoofer setup in my M3. Eventually i will be adding the new JL Audio 100x8 amplifier, but will run the stock HK amp for now. Anybody know how the BSW speakers will respond to a better amplifier? Can they handle an aftermarket amp or are they just meant as stock replacements to be run off the stock HK amp? Thanks!
Dmacmilitant is offline   Reply With Quote
Old 03-15-2013, 11:13 PM   #2
ANREC330
My Ride: C6 Vette & M3
They sound way better than stock just run it with the stock amp. It's not worth the hassle of swapping amps.
ANREC330 is offline   Reply With Quote
Old 03-16-2013, 08:45 PM   #3
MuddZHP
My Ride: 2003 BMW 330i ZHP
They sound better with an after market amp, but it is some work to set up.
MuddZHP is offline   Reply With Quote
Old 05-18-2013, 06:04 AM   #4
lowly323
My Ride: 323
Its definitely worth the hassle of switching amps. Just tap into the Line outs before the stock amp.
lowly323 is offline   Reply With Quote
Old 05-18-2013, 10:25 AM   #5
mochi
My Ride: m3
Wait for the plug and play amp from bsw.
mochi is offline   Reply With Quote
Old 05-18-2013, 08:21 PM   #6
lowly323
My Ride: 323
I wouldn't wait. Put a killer amp in there.
Old 05-18-2013, 09:52 PM   #7
TnT817
My Ride: 01 330ci
Swapping the amp is fairly easy. There are diagrams all over to tell you what wires are what. Then just 1 wire at a time cut it off the plug and label it. Definitely worth the upgrade because the factory amp doesn't have enough output to power the speakers loud and clear. Sure replacing a 10yr old speaker will sound better at low volume but once they get to higher volumes the amp is going to be your enemy and clip your brand new speakers and can ruin them.
TnT817 is offline   Reply With Quote
Old 05-22-2013, 03:46 PM   #8
Halston@BSW
My Ride: E30 X5 TJ
Our speakers can handle ~65W RMS so the ceiling is there for more power! I would give it a run without an amp to start and enjoy. Most comment it is how they wanted their car to sound from the beginning. Thus would not have been on the forums/google trying to find an upgrade
Don't forget to add the Stage 1 to your cart first. Will get 50 off the subwoofer! If you need anything else please let me know!
Halston Pitman
rhp@bavsound.com | ext. 104
BSW | Audio Solutions for YOUR BMW
www.bavsound.com | 404-963-8857
iPod Integration | Plug & Play Speakers | Subwoofer Solutions | Satellite Radio | HD Radio | Bluetooth
Halston@BSW is offline   Reply With Quote
Old 05-24-2013, 10:35 AM   #9
ILLuSioNz X
My Ride: 03 TiAg E46 M3 Coupe
65W RMS at what OHM? I thought your speakers ran at 3 OHM?
-Chauncey
2003 E46 M3 COUPE
Check out my for sale threads: Misc. OEM E46 M3 Steering Wheel Parts | (2) H&R 2.5" 650lb/in coilover springs - $85
ILLuSioNz X is offline   Reply With Quote
Old 05-25-2013, 10:29 PM   #10
TnT817
My Ride: 01 330ci
3ohm is only for HK package. 2ohm is for a non-HK package.
Old 05-26-2013, 02:36 AM   #11
lowly323
My Ride: 323
This pretty much sums up all of my findings. Put a good amp in and you can find many great speakers on the market that will fit. From what I understand the Diamond Audio Hex's bolt right in. Others may need a bit of simple modification to the speaker rings but nothing to worry about. But again if you are powering them with the stock amp you are going to run out of headroom fast. If you are already planning to add the JL amp than no need to add the BSW setup. There are way better options out there for the money IMHO
Old 05-26-2013, 07:16 AM   #12
eriksen76
My Ride: BMW 318D 2004
I'm running stage 1 package with stock H/K amp, sounds great in my opinion I like good and clean sound, this fills up my needs.
I have a aftermarket sub in the boot aswell.
eriksen76 is offline   Reply With Quote
