Sponsored by The Tire Rack
Old 03-15-2013, 10:12 PM   #1
APOG
My Ride: 2002 BMW 330ci
Should I buy these wheels?
Hi Guys,
I am looking for a set of summer wheels for my 2002 330ci. I wonder if these M6 replicas I found on Cragslist will fit/if you think its a good deal. I like the way they look as long as the reps are good quality.
http://hartford.craigslist.org/pts/3661466366.html
The size is what worries me. Tire is 265 wheel height is 18 and the width is 8.5. Will these fit without modifications like rolling fenders, or using spacers. They're square around to that i can rotate them.
I have read 100 posts about the topic without a definitive answer. I wish someone would make a "Will it fit my e46 guide."
Thanks for the help. Love my Bim
APOG
APOG is offline   Reply With Quote
Old 03-15-2013, 11:28 PM   #2
Redline4
My Ride: 02' 330Ci
Send a message via AIM to Redline4
Without doing the research I'd say they would since the offset isn't too bad and they are 8.4 wide which isnt too wide at all Get them your getting a decent deal.
http://forum.e46fanatics.com/signaturepics/sigpic201481_1.gif
Redline4 is offline   Reply With Quote
Old 03-16-2013, 01:16 PM   #3
fth001
My Ride: 325i, e36m3, s13
Can't give a definitive answer because the seller didn't provide enough info. You need to know the offsets (shouldn't be a problem with an 8.5 wheel but always good to know), hub bore size (E39 hubs are 74mm, yours are 72.5mm so will need to buy rings), and tire aspect ratio (5 series cars had larger series tires so a 265/40 would be a lot of tire for a 3 series). I had a 19" set from Mod Bar. shipped to Hawaii for a lot less so I would shop around more.
fth001 is offline   Reply With Quote
