Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southeast
Southeast
AR AL GA FL KY LA MS NC SC TN
Old 07-09-2013, 10:15 AM   #141
glhx
My Ride: 2002 330ci
My car right now. Not going to make that one
glhx is offline   Reply With Quote
Old 07-09-2013, 04:45 PM   #142
2lgt2qt
My Ride: 325i
Any body from TN?
Throw some donuts on her and roll!
Step one; no dsc
2lgt2qt is offline   Reply With Quote
Old 07-09-2013, 04:46 PM   #143
2lgt2qt
My Ride: 325i
Any body from TN?
Im still part of a decent sized bmw group in atlanta. Ill be meeting up with them in Tennessee to continue a caravan there, just a fyi, plenty of bimmers to roll with
Step one; no dsc
Old 07-09-2013, 10:21 PM   #144
glhx
My Ride: 2002 330ci
Been down since march.
Drive shaft
Shocks
Abs module
Steering guibo
Drive shaft. Guibo
Full respray paint job
Valve cover gasket
Full besian vanos kit
Grom audio..................and on and on and on
Old 07-27-2013, 04:26 PM   #145
bhbeisel
My Ride: M3 convertible
I am recommending we go to Land Between The Lakes, just north of Dover TN. I have driven this route many times and love the twists and turns. Ft Henry road and the south half of the Woodlands Trace National Scenic Byway make a great drive thru some of the most beautiful woodlands you will find. We could meet in Dover and there are several ways to return to where each person started from. Fall is not far away and when the oak trees change this would add to the scenery.
bhbeisel is offline   Reply With Quote
Old 07-28-2013, 11:10 PM   #146
ikeupinya
Stay modded my friends!!!
ikeupinya's Avatar
My Ride: 05 ZHP
^^^I'm down!!! From Fort Campbell so I would start from Dover...what date do you have in mind???
Da Lil' Paratrooper!
ikeupinya is offline   Reply With Quote
Old 07-29-2013, 07:11 PM   #147
bhbeisel
No date in mind, interested in what would work for everyone interested. I may just have to pick a date and see who shows. I drove it yesterday and the weather was perfect. It would be nice to work in a connected activity. No one else has replied so it may just be the two of us. I am interested in others that have interest in sharing on our cars and our plans for them.
Old 07-29-2013, 08:55 PM   #148
MiniD
My Ride: E46 ZHP, E90 330i
Harper's Cars and Coffee, August 18th, at West Town Mall (8AM) is going to be huge!
MiniD is offline   Reply With Quote
Old 07-29-2013, 09:02 PM   #149
bhbeisel
A little more info on the location required. Knoxville?
Old 07-29-2013, 11:05 PM   #150
ikeupinya
ikeupinya's Avatar
My Ride: 05 ZHP
Also Nashville's Exotic Cars & Coffee this Saturday, August 3rd from 8-10:30am at the Cool Springs Carmike Theater parking lot in Franklin.
Old 07-30-2013, 09:55 PM   #151
ikeupinya
ikeupinya's Avatar
My Ride: 05 ZHP
I would love to drive through LBL with its fall colors so when would it be the ideal time, middle September??? It would also be awesome if we can get more Fanatics in for this LBL fall drive!!!
Old 07-31-2013, 08:24 AM   #152
MiniD
Yes, Knoxville at West Town Mall.
https://www.facebook.com/events/667800566570342/
Old 07-31-2013, 10:06 AM   #153
bhbeisel
late september/early october best for fall colors.
Old 08-02-2013, 06:55 PM   #154
ikeupinya
ikeupinya's Avatar
My Ride: 05 ZHP
Ok I can wait until then...
Anybody going to Cars & Coffee tomorrow in Nashville???
Old 08-02-2013, 06:58 PM   #155
matrix0099
My Ride: BMW E46 328ci 1999
sorry!!
matrix0099 is offline   Reply With Quote
Old 08-02-2013, 07:00 PM   #156
matrix0099
dear all i am facing a problem with my BMW E46 the fuel pump just broke down and i bout a new one Pump & the Gage when i adjusted to the tank i faced a problem with the Fuel Gage it didn't goes up???
I tried so many times to take out the Fuel pump out from the tank and see whether i adjusted in a wrong way but, the same wrongheadedness:.
In the first time i adjusted the fuel pump it works for 3 days and then it stuck on the 1/4 and every time i put gasoline it goes to the full, after few days either it is empty or full it will remain on 0
What i should do????
please help if any one has any idea
thank you
Old 08-02-2013, 07:45 PM   #157
indoafro
My Ride: 325ci
thank you
clean the gage inside the fuel tank...you should can pul it out..check the gage if its damaged or not...
indoafro is offline   Reply With Quote
Old 08-07-2013, 11:30 PM   #158
glhx
My Ride: 2002 330ci
There are 2 sending units that work together. The fuel pump itself has a gauge built into it. On the drivers side is another gauge by itself. Keep in mind.......it's not a matter of..............the drivers side gauge controls one half of the gauge on the dash and the passenger side controls the other side. It doesn't work that way. They literally work together at the same time at all times.
There is also a siphon built into the tank. The tank is separated into 2 parts. The driver side tank is sucked dry when the passenger side gets too low. This is always constant and the fuel pump pumping gas to the engine creates a vacuum that causes this. This siphon has to have a good seal.
Go to www.realoem.com and type in your vin.....you will see an exploded view of what the fuel system looks like
The way you deal with the gauge problem.......the fuel we use today has sulphur in it. The cheaper gas you use the more sulphur it contains. Higher end gas also has cleaners built into it. Especially premium fuel. You can suplement this by adding techron to your tank as directed to help clean the system.
Then clean the gauge of the sulphur deposits....get a tooth brush and some electrically safe solvent.....the kind of stuff used to clean the maf sensor. You will see the slider on the sending unit become shiny again. Be gentle with it and the cleaning of it. Right now the sending unit is making contact with the sulphur build up instead of the slider on the gauge. When BOTH sides are shiny and clean.....they will once again work together and the gauge should show correctly.
.........on another note...get bmw scanner 1.4.0 on a lap top. There is a gauge test in there that will sweep the gauge and give you indication if it is the gauge itself. You need that software anyway for everything. It is the first thing you should purchase when you buy your car. You can also refer to your OBC. Your obd2 will need the special cable. You have one port under the dash. The main one is near the drug bin and is circular
Old 08-08-2013, 09:12 AM   #159
MiniD
Knoxville guys:
We are having a big meet up before Cars and Coffee at Chic Fila in Turkey creek at 7:15-7:30 on the 18th. We have like 15 + cars confirmed as of right now.
Old 08-18-2013, 07:48 AM   #160
2lgt2qt
My Ride: 325i
Any body from TN?
Originally Posted by MiniD View Post
Knoxville guys:
Im running a little late. Which part of parking lot will you all park?
Step one; no dsc
