///M3 Forum
Old 03-16-2013, 04:26 PM   #1
03BIMMERM3
My Ride: 2003 BMW M3
Help with rear view mirror setting when in reverse
Does anyone know how to adjust the setting for the rear view mirror when going in reverse? My mirror adjusts really low, not useful..have somthing to do with the setting of the seat?
Sent from my myTouch_4G_Slide using Bimmer App
03BIMMERM3 is offline   Reply With Quote
Old 03-16-2013, 04:37 PM   #2
taveet330i
My Ride: Jet Black 2002 330i
If the mirror tilts down when the reverse gear is engaged, that means that the mirror adjustment switch os on the left side. If you slide the switch below the knob to the right, it should stay put in reverse
[bimmerapp]
_______________
Dedication
2002 Jet Black 330i|ZPP|Hellbeige interior|Carbon Fiber Interior Trim|Alzor 703 CSL Reps|Custom Flowmaster Catback Exhaust|LED Halo Rings|Black ECSTuning Kidney Grilles|Eonon D5150|
taveet330i is offline   Reply With Quote
Old 03-16-2013, 04:42 PM   #3
03BIMMERM3
So when I put the car in reverse, my right mirror adjusts down..you say the setting is on the left..how do I adjust..not followin u
Old 03-16-2013, 05:05 PM   #4
Slyde
My Ride: 2001 M3 TiAg
So, you want the mirror to adjust when backing to observe curb and rear tire, but do not like the position the mirror uses and want the mirror to adjust to a different angle that works better for you?
Slyde is offline   Reply With Quote
Old 03-16-2013, 05:05 PM   #5
Marshmallow
My Ride: Ehhh...
Change the mirror selection switch on the door to right side mirror to stop the tilt down.
Marshmallow is offline   Reply With Quote
Old 03-16-2013, 05:15 PM   #6
03BIMMERM3
Yes, right now, the tilt is so low..gonna play around with it, I just can't find a way to adjust the tilt
Old 03-16-2013, 05:55 PM   #7
Marshmallow
My Ride: Ehhh...
I believe there is a way you can program how much it tilts but I do not know the details.
Old 03-16-2013, 07:10 PM   #8
Alan
Alan's Avatar
My Ride: 2006 M3
It can be GT1 programmed with reverse tilt on or off. I've never heard of being able to auto adjust the tilt angle.
OP: All of this is in your manual.
Alan is offline   Reply With Quote
Old 03-16-2013, 07:11 PM   #9
UntaM3d
My Ride: 05 ///M Convertible
Sub'd
I need the answer also. It tilts too low. My old E46 only tilted about 1/2 as much
UntaM3d is offline   Reply With Quote
Old 03-16-2013, 07:24 PM   #10
Marshmallow
My Ride: Ehhh...
You're probably right, but I'm still wondering about it. I've heard that if you put the car in reverse, let the mirror tilt down, then adjust it to the position you want, disengage reverse, it will memorize that position.
Old 03-16-2013, 07:24 PM   #11
Alan
Alan's Avatar
My Ride: 2006 M3
Originally Posted by MyNewRag View Post
Sub'd
BMW intentionally had it tilt very low. The reason for that is to be able to see a curb and the distance to the rear tire when parallel parking.
Old 03-16-2013, 07:56 PM   #12
gimmethemuumuu
My Ride: '17 F80 M3, SO/Bk
As mentioned, this can be coded. Specifically, without coding, the mirror will point _way_ down--one position, like it or not, use it or don't. With coding, when in reverse, you can adjust the mirror to where you want it to be. Then, the next time you reverse, it will go back to the new position you've set.
gimmethemuumuu is offline   Reply With Quote
Old 03-16-2013, 08:03 PM   #13
03BIMMERM3
Doesn't work... tried it, only way I got it a pinch up is by moving the seat
Old 03-16-2013, 08:04 PM   #14
03BIMMERM3
Dont have the manual, Gt1 programmed?
Old 03-16-2013, 09:08 PM   #15
olivierE46M3
My Ride: E46 M3 2003
Are both mirrors supposed to tilt down on reverse? only passenger mirror on my M3 tilts????
olivierE46M3 is offline   Reply With Quote
Old 03-16-2013, 09:25 PM   #16
Alan
Alan's Avatar
My Ride: 2006 M3
Check your mirror slide switch.
Old 03-16-2013, 10:32 PM   #17
UntaM3d
We know the reason, but the manual states that the angle is adjustable, but does not say how. As stated earlier, it is a matter of how far it will tilt, not if it will tilt and why.
To the poster about both mirrors...to my knowledge it is only the passenger mirror
Old 03-17-2013, 10:25 AM   #18
FreddyM3
My Ride: M3
One way to get it to stay where you want it is to position it where you want it and program your seat button to keep the chosen mirror position.
FreddyM3 is offline   Reply With Quote
Old 03-18-2013, 08:17 PM   #19
Cazz
My Ride: 2005 BMW M3
Try this:
http://forum.e46fanatics.com/showpos...94&postcount=5
Cazz is offline   Reply With Quote
Old 03-18-2013, 08:25 PM   #20
Marshmallow
My Ride: Ehhh...
Originally Posted by Cazz View Post
I knew I read something about that! Thanks for posting it!
