///M3 Forum
Old 03-16-2013, 08:59 PM   #1
Ramseyd
My Ride: Bmw e46 M3
really.. HELP
SMG wont start, tried the "making sure the trunk and hood are shut thing". The breaks stiffer then all he*l. i tried pushing hard on the break.." i read about that " i turn the key two clicks see its in N then press break and no start.. all my lights are bright and i even hooked up jumper cables to give it a shot.. Is there anything at all i can do? anything? please help. :/
Ramseyd is offline   Reply With Quote
Old 03-16-2013, 09:14 PM   #2
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
If your brake pedal is hard, you are going to have to press real hard to move the pedal to de-activate the safety lock.
You can also disconnect your battery for 30 minutes. The reconnect and see if everything resets.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 03-16-2013, 11:03 PM   #3
Ramseyd
My Ride: Bmw e46 M3
Just tried all that. Now what? Should I get a salmon relay now?
Old 03-16-2013, 11:07 PM   #4
turbo_f22_pilot
Salmon relay wouldn't hurt. Does the brake pedal move? You'll be able to feel the gear lever unlock. Does the pump prime? Is the gear indicator solid or flashing?
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 03-16-2013, 11:16 PM   #5
Ramseyd
My Ride: Bmw e46 M3
The break petal is super stiff, gos into neutral. You can hear the pump so that's fine. It just won't start..
Old 03-16-2013, 11:59 PM   #6
Ramseyd
My Ride: Bmw e46 M3
If it's not the salmon relay what could it be?
Old 03-17-2013, 12:12 AM   #7
turbo_f22_pilot
If you replace the relay and that doesn't solve it, your problem is more than likely your starter.
You have to make sure all the simple things are checked first. Battery terminals tight. Battery fully charged. Key/s working properly. Hood properly closed. Brake pedal is pressed HARD to engage safety switch. SMG pump primes. SMG changes from "R"/"1" to "0"/"N" when pressing the brake pedal.
After that, it's electronic troubleshooting. Codes need to be read.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 03-17-2013, 12:32 AM   #8
Ramseyd
My Ride: Bmw e46 M3
Ok I've dove everything but the salmon relay and codes. Is there anyway I can fin out exactly what it is? Or do you just suggest buying a new relay? Also the break is very stiff mind you. And I have already tried pushing it hard.
Old 03-17-2013, 01:20 AM   #9
turbo_f22_pilot
After swapping the relay, you have to perform computerized troubleshooting. The first place to start is to see what the car thinks is wrong. From there, it get tricky and expensive.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 03-17-2013, 09:29 AM   #10
Ramseyd
My Ride: Bmw e46 M3
No codes came up. Should I still get the relay? I can right now
Old 03-17-2013, 10:27 PM   #11
turbo_f22_pilot
Sorry for the delay, but mostly check the forum at night. If you haven't gotten a relay yet, get 2 first thing in the morning.
I say this all the time, "ALL SMG owners should have a spare salmon relay."
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 03-17-2013, 10:28 PM   #12
Ramseyd
My Ride: Bmw e46 M3
Why two? I just ordered one..
Old 03-17-2013, 10:35 PM   #13
turbo_f22_pilot
They have been know to be questionable sometimes. Plus if it works you now have a good spare for if / when the new one fails.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 03-17-2013, 10:37 PM   #14
Ramseyd
My Ride: Bmw e46 M3
Ohh ok I understand. Also do you know if there is any sort of reader that would tell me straight up what my issue is?
Old 03-18-2013, 12:43 AM   #15
swoobies
My Ride: '03 M3
this happened to me recently. I really had to push down the brake pedal to get it to unlock and turn on lol
swoobies is offline   Reply With Quote
Old 03-18-2013, 12:48 AM   #16
Ramseyd
My Ride: Bmw e46 M3
I mean i pressed mine pretty hard haha but i guess i will give it another go tomorrow, anything helps really. Did you like slam the break peddle?
Old 03-18-2013, 12:50 AM   #17
Ramseyd
My Ride: Bmw e46 M3
Also guys my car is parked on a hill in front of my house. Im not sure if the incline may make a difference or not but i thought i'd just throw that out here
Old 03-18-2013, 01:19 AM   #18
turbo_f22_pilot
The answer to that question is NO! Although with the proper diagnostic tools, you can easily isolate the problem in a reasonable amount of time. The automated diagnostic tools (GT1 / ISIS) can perform electronic tests and provide flow charts for T/S assistance. Most problems are easily diagnosed via error / fault codes.
Certain component failures won't generate an error code because the component isn't being monitored by the control modules.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 03-18-2013, 01:22 AM   #19
Ramseyd
My Ride: Bmw e46 M3
Hmm alright, Well what do you suggest i do about the situation i am in? Wait for the salmon relay or are there things i could try?
Old 03-18-2013, 01:37 AM   #20
turbo_f22_pilot
Check the battery cables (tight and clean), check the battery (fully charged), try a different key if you have more than one (if not, get a spare), rock the car slightly and see if the pedal get easier to press. Disconnect the battery for several hours.
Access to the starter is a pita.
Joy is future proof
CAR:
MODS:
BMWCCA NCC
