///M3 Forum
Old 03-18-2013, 02:41 AM   #21
Ramseyd
My Ride: Bmw e46 M3
Originally Posted by turbo_f22_pilot View Post
Check the battery cables (tight and clean), check the battery (fully charged), try a different key if you have more than one (if not, get a spare), rock the car slightly and see if the pedal get easier to press. Disconnect the battery for several hours.
Access to the starter is a pita.
If i remember correctly when i put the car in N earlier and put down the e-break as i drifted forward my break peddle loosened up and then when i tried to star it it went stiff. Im not sure if that means anythig?
Ramseyd is offline   Reply With Quote
Old 03-18-2013, 09:28 AM   #22
$ilent ///M
My Ride: 03.5 M3 smg lsb
Your brake pedal will feel hard because there is no more vacuum assist from the brake booster. the engine needs to be running to create vacuum to replenish the vacuum in the booster. Just try the relay first especially if you dont hear the smg pump prime when first waking up the car. can you cycle the gears from r-n-1-2 with no issues with engine off?
$ilent ///M is offline   Reply With Quote
Old 03-18-2013, 02:17 PM   #23
Ramseyd
My Ride: Bmw e46 M3
Yes i can
Old 03-19-2013, 05:40 PM   #24
Ramseyd
My Ride: Bmw e46 M3
UPDATE: the issue was the key..
Old 03-20-2013, 09:11 PM   #25
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Congratz
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 03-20-2013, 10:37 PM   #26
Cayne23
My Ride: 2002 m3 convertible
Sorry just my 2 cents. I have a 6mt. But i know u have to press the brake pedal to start the car. If your pedal.is to stiff to press, u could bleed your brakes using the.bleeder valve.at one of your calipers. Just a thought
Cayne23 is offline   Reply With Quote
