Dyno sheets of s54 7175 - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-17-2013, 05:03 PM   #21
Vdo s54
My Ride: Bmw m3 turbo
On track
Vdo s54 is offline   Reply With Quote
Old 03-17-2013, 05:04 PM   #22
Vdo s54
Engine with low mount turbo 2012
Old 03-17-2013, 05:13 PM   #23
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
Can you give us some details about the sellholm mpg seq gearbox, is it noisy , and any install pics ?
Providence is offline   Reply With Quote
Old 03-17-2013, 06:20 PM   #24
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Originally Posted by Vdo s54 View Post
Here is a picture of my graf with 7175 at 1.7 bar of boost ,e85 ,vanos block 2.2 mm lift at inlet 1.6 mm lift at exhaust at tdc.but unfortenly i have to go of the gas,becouse it was leaning out,bad fuel pump i have changed it now and i also made me a new topp mount exhaust manifoil and a new 7675 turbo,so i will tune it again soon..waiting for my new selholm MPG seqensial gearbox to arrive first i have also a fully portet head with 1 mm oversize valves ,stock cams,and 9.5/1 in comp...it was pushing 800whp at 1.4 bar as you see here,but i have problems to hold boost on the first pull here as you can see on the curves,the turbo was also brokenso it was peaking 1.4 bar and was falling down to 1.1 bar...
Why the switch from the 7175 to the 7675?
Old 03-18-2013, 10:47 AM   #25
Vdo s54
The old 7175 gave up with a broken air filter More horsepower is the reason for going the 7675 precition... Has anyone tried the ball bearing version vs journal bearing?
Old 03-18-2013, 11:48 AM   #26
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
A 71/75 is capable of about 1150 rwhp if all the surrounding parts are right. I would stay with what you have and find out whats holding you back. Just my 2 cents. Good luck!
Saad @ Saad Racing is offline   Reply With Quote
Old 03-18-2013, 12:44 PM   #27
Vdo s54
1150whp with 7175? That cant be right we have a lot of m3 turboes here and thay all give 1000-1050 whp at 29 psi of boost...with 7675 And thay also have 30 psi in backpressure on the 96 ar turbo... I have seen 950whp on 7175 on 34 psi of boost..
Old 03-18-2013, 12:55 PM   #28
7to3_enthusiast
My Ride: '02 AW 6spd M3
+1
Maybe you're hitting the 1000-1050 rwhp S54 bottle neck plague that many tuners in the US are starting to see?
I've seen similar results with Sound Performance and HPF. Make amazing power up to 1000 rwhp then the turbo struggles to squeeze more air into the motor . Bdave, among others thought it might be the manifold but tubular manifolds have net similar results. Leaves me to believe more r&d is needed for the head or maybe need a larger cam?
94 VR R2 Rx7 SOLD
02 AW/IR M3 MaxPSI 2(.5) PT 6870, 3.5" custom exhaust
14 CW 1.8T Beetle - Wife's dream car
02 4.6is X5 - The Work Horse
04 LSB M3 SOLD
7to3_enthusiast is online now   Reply With Quote
Old 03-18-2013, 01:28 PM   #29
E85head
My Ride: E46 M3
Originally Posted by 7to3_enthusiast View Post
+1
I thougt it was well documented that the s54 head is flowing more then a 2jz could ever dream? Maybe Saad have some theory on this?
Has anyone investigated the design of the throttlebodies?
E85head is offline   Reply With Quote
Old 03-18-2013, 01:35 PM   #30
Cipri
My Ride: E46 M3 2002
US horsepower are not the same with EU horsepower, ours are stronger
Cipri is offline   Reply With Quote
Old 03-18-2013, 01:55 PM   #31
Vdo s54
Yes i also think that, all engines have more horsepower in us i think.. Maybe they measure in another scale? I have dynoed a lot of americans V8 and all misses 50-100 hp... i find that strange? 1150whp on a 7175 cant be done on a s54,take Andreas he is running a huge 8285 and still havent reach 1150 whp so i realy wont to see prof of that...
Old 03-18-2013, 02:18 PM   #32
7to3_enthusiast
I think it has been proven as well that the s54 head does flow more than the 2JZ. Guess that just leaves valve duration then. Maybe we've reached the limit that vanos can provide.
94 VR R2 Rx7 SOLD
04 LSB M3 SOLD
Old 03-18-2013, 03:32 PM   #33
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
Its not the Head, cam or Vanos. Its the turbo system and ECU/tune. As far as US horsepower reading higher, forget that nonsense, use trap speed if you want to compare.
My turbo kit will make around 900-950 rwhp on a 67/66 and will trap about 150 mph. If you put a 71/75 on my kit the car should trap in the 160's.
The restrictions you are seeing are in the air intake, downpipe and header. After that the ECU/tune. Good luck.
Old 03-18-2013, 04:18 PM   #34
m3micke
My Ride: e46 m3
m3micke is offline   Reply With Quote
Old 03-18-2013, 04:24 PM   #35
E85head
My Ride: E46 M3
Originally Posted by m3micke View Post
What do you think Micke?
Old 03-18-2013, 04:27 PM   #36
m3micke
My Ride: e46 m3
Dreams ,wer in norway do you live
Old 03-18-2013, 04:30 PM   #37
E85head
My Ride: E46 M3
PM sent
Old 03-18-2013, 07:08 PM   #38
Saad @ Saad Racing
Past Site Sponsor
My Ride: S600
What does that mean? If you have something to say why not just say it?
Old 03-22-2013, 06:45 AM   #39
dragosid
My Ride: HPF 2.5 M3
Serious gearbox there, quite expensive too. Curious of your feedback on it and whether it would be streetable.
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 03-26-2013, 09:16 AM   #40
Vdo s54
Here is my car directly from painting,now will it be the vdo m3 stickers on the car same as thay use in motorsport
