Old 03-17-2013, 06:07 PM   #1
dwsounddesign
My Ride: 2002 BMW 330xi
Angry What's wrong with car
dwsounddesign is offline   Reply With Quote
Old 03-17-2013, 06:53 PM   #2
haurelio
My Ride: 2001 bmw 325i
have you try disconnecting the battery?
Contact me if you need to unlock your phone.
Also can code your car
Old 03-17-2013, 06:57 PM   #3
lcoleman
My Ride: '79 Massey Ferguson
Looks like the hidden menu for RPMs--interesting. I would disconnect the battery as suggested, then do the ign swtich as suggested in your other thread.
Old 03-17-2013, 07:19 PM   #4
dwsounddesign
i disconnect the battery and place it back on every morning now for a week. otherwise my battery will die cause of this issue. when i do connect it some mornings, it won't fault out like that.
Old 03-17-2013, 07:23 PM   #5
lszlszx
My Ride: 1.8T, XC70
There must be a short somewhere, check the wires around the ignition switch
first, wiggle the wires.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-17-2013, 07:46 PM   #6
lcoleman
I'd say they're the same issue. A parasitic draw test would probably point you in the right direction. Inspecting grounds is a good suggestion.
Old 03-17-2013, 08:04 PM   #7
dwsounddesign
I've checked and cleaned all ground connections. I just noticed today while driving. I had my OBC computer on the mpg function cruising on the highway. But strangely, I heard a beep, and looked down and the temperature was now on my OBC computer....(as if I started the car) weird...
Old 03-17-2013, 08:17 PM   #8
lcoleman
That happens any time it drops below 37 degrees F. Did you install your new ign switch?
Old 03-17-2013, 08:27 PM   #9
dwsounddesign
not yet I just picked it up today from Keeler BMW. I'll do it in the morning following some more testing. I already checked fuse 67 and 14 which was another mentioned to me (immobilizer)
Old 04-05-2013, 10:53 AM   #10
dwsounddesign
It was fixed. It was the light control module. Fixed everything
Old 04-06-2013, 08:17 AM   #11
dwsounddesign
Bill came out to 595.80
Old 04-06-2013, 10:00 AM   #12
lszlszx
My Ride: 1.8T, XC70
It didn't throw a code?
Old 04-06-2013, 10:06 AM   #13
dwsounddesign
No. When I went to autozone for the code reader, it only reads the engine/transmission and air/fuel diagnostics. Mine was the computer issue of the LCM still sending power to the various units when I took the key out. Apparently, you can buy a used LCM but u cannot recode it to another used car, but if you install it anyway, the headlights/turning signals won't be nearly as bright as before. In my case, that's the price for a new LCM coded with my car and now everything is fine. Time for 10000K xenon kit with my projector lens.
Old 04-06-2013, 10:08 AM   #14
dwsounddesign
Oh and forgot to mention there was a recall for tail light grounds on my car
