Old 03-17-2013, 11:40 PM   #1
E RaK
My Ride: 2001 325xit
There's a bird in my car - HVAC noises
So this winter I've come across a new niggling issue. On cold mornings, the HVAC fan makes a beautiful chirping noise for 2 or 3 minutes before the air in the system gets warm. It's not too loud, but definitely a little annoying. Any suggestions? I don't need potential buyers looking for a nest under the hood.
E RaK is offline   Reply With Quote
Old 03-18-2013, 03:33 AM   #2
paraklas
My Ride: ESS TS2 320ci
http://forum.e46fanatics.com/showthr...blower+fan+diy
Old 03-18-2013, 03:45 AM   #3
djantlive
My Ride: E46 M3
Change cabin filter first. That could solve it without changing the fan itself. Sometimes it is caused by leaf
djantlive is offline   Reply With Quote
Old 03-18-2013, 08:03 AM   #4
Sweetness
My Ride: '01 325i
Before you replace the main blower fan, try and replace the climate control panel, which houses it's own little micro fan that likes to "scream" a lot. There's two versions. One is very deep, very crude, and has a big fan. This is the one that has the fan control buttons on the bottom of the panel. The newer version is shallower, cleaner, and has a smaller fan. This one has the fan control buttons on the side of the panel.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 03-18-2013, 08:12 AM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
Mine does that in very cold mornings too. It's really annoying. It comes directly from the center blower area, so I am positive that the blower fan is it. Problem is, that sucker is expensive.
http://www.ecstuning.com/BMW-E46-330...ower/ES240464/
Ouch.
http://www.ecstuning.com/BMW-E46-330...wer/ES2129904/
This is much cheaper, but I question its quality since it is MTC...
Old 03-18-2013, 08:20 AM   #6
Sweetness
My Ride: '01 325i
^MTC Fans have known to go bad or noisy within a year or so. If you buy a Bosch Fan, apparently it has dettachable fins that make the install 100x easier
2001 325i ZCW, ZPP
Old 03-18-2013, 08:58 AM   #7
ryannel2003
My Ride: '04 Cadillac Deville
64113453729
$120 for Behr fan assembly. The part number above was superceded by this one.
ryannel2003 is offline   Reply With Quote
Old 03-18-2013, 09:03 AM   #8
JJR4884
My Ride: BMW
Spring is right around the corner, turn your radio up for the first couple minutes
JJR4884 is offline   Reply With Quote
Old 03-18-2013, 04:30 PM   #9
E RaK
I certainly am doing this
Is there any way to determine whether or not the climate control unit is the issue once it is out of the car?
Assuming it doesn't have to do with the cabin filter, neither piece is looking to be a cheap fix
Thanks for the info and PNs guys.
