Old 03-18-2013, 06:04 AM   #1
ThreeOhFive
My Ride: 2002 330i
Engine overrevved, runs rough
I went to pass a vehicle a vehicle, hit third, I think I bumped it outta third into nuetral. I was in it hard, rpms raced to redline. It overrevved pretty bad. The car immediately started running rough and shut off. I was able to limp it a few more miles. It will not idle, if rpms drop below 3k, it dies. Checked under the hood, ac belt shot off, it's still in one piece. It's not knocking, no ses??? It's missing pretty bad, though under 4k.. If you rev it, it sounds okay, as long as its above 4k.
Did I blow it? It had an engine replacement at 69k, it has 107.5k. So what 39k miles on the block?
This is so crappy.
ThreeOhFive is offline   Reply With Quote
Old 03-18-2013, 09:01 AM   #2
fgump
My Ride: '01 325i
Money shift
Likely bent/broken valves or springs. Compression check will probably reveal 0psi in a few cylinders. Don't drive it or run it.
'01 325i
161k miles
bone stock
fgump is offline   Reply With Quote
Old 03-18-2013, 09:17 AM   #3
mgilardi86
My Ride: 02 ///M3 6MT Coupe
Um if you knocked out out of gear even if you had it floored, it isn't going to overrev. The ignition would cut out before then, you would have had to physically put it into too low a gear which doesn't sound like you did. Check all your vacuum lines first
mgilardi86 is offline   Reply With Quote
Old 03-18-2013, 09:23 AM   #4
ThreeOhFive
My Ride: 2002 330i
My car has no rev limiter? It had some boltons when I bought it, maybe a tune as well. Ignition did not cut it out, it went to 7k, I immediately got off the throttle, but it stayed up there for a few seconds.
Old 03-18-2013, 09:36 AM   #5
WDE46
My Ride: '13 128i, '04 330Ci
Our cars are supposed to have rev limiters. That's a serious **** up on the PO's part. You probably just need a new head, not a whole new engine. Take this one to a mechanic.
Old 03-18-2013, 09:51 AM   #6
ThreeOhFive
My Ride: 2002 330i
So the long block should be okay? It's not knocking... Just missing really bad.
Old 03-18-2013, 09:57 AM   #7
WDE46
I don't see why the block would be damaged. All the M54 money shifts (huge 9k rpm over revs) I've seen have only bent the valves severely. You may have just slightly bent some. You'll have to take it to a mechanic for diagnosis though. I don't see why 7000 rpm would blow up this engine. That, and I don't see why anyone would ever totally remove the rev limiter. It's often increased to almost 7k.
Old 03-18-2013, 10:50 AM   #8
ThreeOhFive
My Ride: 2002 330i
That's not cheap. $700 used! What do you all think labor in terms of hours will be? My shop charges about $86 an hour.
Old 03-18-2013, 10:56 AM   #9
ThreeOhFive
My Ride: 2002 330i
I did force the car to drive about another mile to a parking lot, and have started and revved it a few times, trying to see what I could figure out. I won't mess with it anymore, hopefully I didn't make it any worse. I have to tow it an hour home. I've got a car from my parents to last me while I get this fixed. Looks like this repair will be $1,500. I've had the car two weeks, working on $2500 in repairs that have come up in 700 miles.
Old 03-18-2013, 11:02 AM   #10
WDE46
When you do get this fixed, make sure the rev limiter is back in place at 6500 rpm.
Old 03-18-2013, 11:16 AM   #11
Guest021715
Account closed.
With what you described (popping out of 3rd and hitting 7K rpm), NO damage should have occurred.
You may raise the rev limiter to 7k with a tune, but I've never heard of anyone ever removing the limiter.
Did the RPM needle pin itself a bit at its physical limit just over 7K?
I've had a friend money-shift my car once, and yours truly has done it as well. Luckily there was no damage, and both times the engine revved well over 7K.
Old 03-18-2013, 11:47 AM   #12
lcoleman
My Ride: '79 Massey Ferguson
I would investigate why the a/c belt shot off before condemning the head.
Old 03-18-2013, 11:51 AM   #13
WDE46
lcoleman always coming in and keeping us on track by talking some sense. good man. I am also curious why this happened. I definitely overlooked this.
Old 03-18-2013, 02:10 PM   #14
ThreeOhFive
My Ride: 2002 330i
Not sure as to the exact rpm, I didn't see the tach. Had to be 7k, it was coming down past 6500 when I looked. It just got one big rev for like 2 seconds. It was weird I hit third, felt it pull, and the rpms just soared out of nowhere. I'm not new to a manual. This is my third manual trans. Never missed a gear in this car.
Idk what happened. But when it was coming down from the rev, it was super slow, and it shut off on me. It was having atough time starting, but I did get it to get up to 40 and a mile further.
On inspection of engine bay, oil was fine, and belt had shot off. In the prior weeks, I have been hearing an airplane noise coming from the belts when cold, a weird hum, and high pitched noise. Seemed like an idler pulley. Also detected noise from the water pump. It was making noise. A scratching scuffing noise after revs. All this was getting replaced Tuesday. Have the parts in the car.
Old 03-18-2013, 02:17 PM   #15
ThreeOhFive
My Ride: 2002 330i
As for the limiter, it revs in neutral to 67-7000. Only done it once though. I usually was nice to this car. I was being a bit hard on it before this happened. I never redlined it though, one good pull to 100, and it blew on me right after that. I was coming up on probably 60 or 70. 3/4 throttle. Then all hell broke loose, it started screaming.
Old 03-18-2013, 08:29 PM   #16
ThreeOhFive
My Ride: 2002 330i
Zimbrick BMW of Madison will be looking at it in the next few days.
Old 03-18-2013, 11:48 PM   #17
lcoleman
Personally, I would replace these things (plus the a/c belt) before going any further.
It is really hard to overrev a car in neutral, since there is a rev limiter....even if it is raised with a chip from a reputable company. 7K rpms should not float valves or cause any catastrophic failure.
Old 03-18-2013, 11:54 PM   #18
Guest021715
Account closed.
Old 03-19-2013, 12:15 AM   #19
lcoleman
Ahh, ruff...just how your mother likes it.....Trebek!
Old 03-19-2013, 09:28 AM   #20
WDE46
I'll take "The Rapist" for 600!
