Old 03-19-2013, 09:08 AM   #21
ThreeOhFive
My Ride: 2002 330i
Okay guys. I've been replaying this whole thing in my head over and over again. It happened really quickly, but I think I know exactly what I did. I hit third, and was shifting quickily to fourth, and somehow, I caught second, at 70 to 75 mph. The car didn't jolt, just took a 7,000 rpm hit for a second until I engaged the clutch and it died. I can't seem to find any other explanation my fault on his one.
So, hopefully it's just the cylinder head. Like I said 75 max, redline in second is like 65 I think. It's hard to believe a quick mistake could destroy a 40k mile M54, but guess there's nothing I can do now, except be really upset with myself.
ThreeOhFive is offline   Reply With Quote
Old 03-19-2013, 09:09 AM   #22
WDE46
My Ride: '13 128i, '04 330Ci
what RPM were you at in 3rd?
According to my gearing graphs, 70 mph is maybe a little past redline for 2nd gear. That's probably why you didn't feel a jolt. It should have been capable of that RPM, but who knows, maybe the valve springs are rated very accurately (wouldn't be that surprised). Since your engine can still sort of run, I bet you just slightly bent something.
Edit: Actually I had the redline as 6900 rpm instead of 6500. 70 mph in 2nd gear would be 7000 rpm. 75 mph would be almost 7500 rpm.
Old 03-19-2013, 09:27 AM   #23
ThreeOhFive
My Ride: 2002 330i
Had to be between 4.5 and 5k. Maybe a bit over. I was watching the truck in front of me, that's why I upshifted, I was coming up on him in a hurry. To sum up the sound my car made, it was M3-like... she really screamed for a second.
Old 03-19-2013, 09:35 AM   #24
WDE46
You probably put it over the rev limiter by about 1000 rpm.
Old 03-19-2013, 09:43 AM   #25
ThreeOhFive
My Ride: 2002 330i
Lol enough to shoot the ac compressor belt off. I'm so mad at myself.
Dealership is charging me $140 to look at it, they told me they will know probably right away what it needs. But at this point, replacing the entire engine shouldn't be neccessary it seems... Just the cylinder head. It's about $1,000 in labor to do, and $700 for a used head. Anyone know where remans are sold for fair prices?
Old 03-19-2013, 09:50 AM   #26
fiveightandten
My Ride: '03 330ci / '98 M3
Back up....
Have them do a compression test on the engine if they haven't already. No more guessing. 7,000 RPM (if that's really all it went to) should not be enough to bend valves. You need to confirm what the problem is before pulling the engine apart.
Secondary to that...if you get a used head, what are they going to do to it? Do they machine the mating surface? Do they guarantee it for a certain amount of time? Do to do any cleaning, any pressure testing, any refurbishing to it? There's a big difference between a used head that is tested, guaranteed against faults, and decked...vs. a used head that's taken out of a junk yard motor and thrown on yours with fingers crossed.
-Nick
fiveightandten is offline   Reply With Quote
Old 03-19-2013, 04:19 PM   #27
ThreeOhFive
My Ride: 2002 330i
Lol get this. Dealer said fuel pump is shot. Kinda explains why its running bad. But I thought I was looking at an engine?! Right after a money shift, the pump goes?
Old 03-19-2013, 04:25 PM   #28
B Potter
My Ride: 01 330
Lucky bastard.
I'm also impressed so many people here knew it wasn't the valves. Well done.
B Potter is offline   Reply With Quote
Old 03-19-2013, 04:55 PM   #29
Guest021715
Account closed.
The dealer could be talking out of its ass.
Money shifting to 2nd is an entirely different story than what you originally described.
Do a compression test. Buy the tester from harbor freight, pull your spark plugs, and report back your PSI readings for each cylinder.
Old 03-19-2013, 04:57 PM   #30
ThreeOhFive
My Ride: 2002 330i
Dealer said that they had no reason to believe there was any engine problems. No valve train noise or knocking heard.
Old 03-19-2013, 05:08 PM   #31
Guest021715
Account closed.
You can't diagnose a cylinder's compression by ear.
Even if it does end up being your fuel pump, that's a hell of a coincidence, and you still did money-shift your car.
Compression test.
Old 03-19-2013, 05:14 PM   #32
BeMyWhip
My Ride: 01 BMW 330ci
Can it possibly be an electical issue?
Like coils?
just thinking at loud...
Btw, if it will cost $1700 for a head job,
Can you hire a fanatic to help out, or attempt this yourself?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 03-19-2013, 05:44 PM   #33
ThreeOhFive
My Ride: 2002 330i
Called back dealership, they want an additional $200 to test compression. Seems really high. I'm already $75 into service, all they told me is my fuel pump is shot.
Old 03-19-2013, 05:52 PM   #34
RKiepper
My Ride: 1999 E46 328I x2
Compression test.
You can diagnose valve issues though. Pull the plugs, pressurize the cylinder with it at TDC...
If there's noise coming out the intake, it's the intake valves.
Noise from the oil cap, it's the rings.
Noise out the exhaust, well... You guessed it. Lol
Did that all the time back in school doing rundowns on aircraft engines. A whole lot easier then pulling a jug.
All the aircraft engines we worked on were air cooled, nothin liquid. So we never messed with head gaskets. But if there's air comin' out the radiator fill, your head gasket is shot. So I'd open that up too, just in case.
RKiepper is offline   Reply With Quote
Old 03-20-2013, 01:01 AM   #35
ThreeOhFive
My Ride: 2002 330i
I'll just cough up the $200 and get the compression test.
Old 03-20-2013, 08:47 AM   #36
WDE46
I wouldn't quite put OP's situation into "money shift" territory. He was mid-upper range on a gear and downshifted into a little over the maximum on the next gear. According to OP, worst case is that the engine reached 7500 rpm. I really don't think that bent anything, but like I said, maybe the RPM limiter gives a smaller margin for error than we think. As for why that threw the AC belt off, I don't know. Maybe because he made no attempt to do a proper rev match at all(b/c he though he was upshifting). Fuel pump seems like quite a coincidence but weirder things have happened. I would just do that for the hell of it anyway, especially if it's original. If it fixes it, awesome, if not, you have a new fuel pump. Either way get that compression test and leak down test done.
Old 03-20-2013, 09:00 AM   #37
fgump
My Ride: '01 325i
We are all armchair mechanicing.
Check the valvetrain. If it's fine, move to fuel, then electrical. But as you significantly overrevved, either by popping out of gear, or by going from high rpm in 3rd to higher rpm in 2nd, there is the risk.
Heck, even weirder things have happened; M42 engines in the 318is were known to have the cams jump time at overrev, which made them either run like cr@p, or bend valves.
Do the compression/leakdown test. If nothing else, you'll know the condition of your rings and valves if they are good (compression numbers relative to spec).
'01 325i
161k miles
bone stock
fgump is offline   Reply With Quote
Old 03-20-2013, 10:09 AM   #38
lcoleman
My Ride: '79 Massey Ferguson
Why? The dealer can see the car. We can't. Also, $200 is pretty steep for something that would take you 2 hours at most.
Old 03-20-2013, 01:42 PM   #39
ThreeOhFive
My Ride: 2002 330i
Can the dealership do a compression test without the car warmed up? It barely runs due to the low fuel pressure. The dealership it came from is 3 hours away, the local dealer is the one looking at it. They are asking for a fax of the diagnosis of the vehicle after Zimbrick is done checking it out.
Old 03-20-2013, 01:56 PM   #40
lcoleman
Yes, but the results are better on a warm engine. I would say they'll fix the fuel pump, then do the test.
